This was the first I'd heard of this brand - had to look it up out of curiosity.
Looks like a great little P&S to me. Here's the B&H page with what appears to be relatively comprehensive specs. I also looked at the amazon listing for it, and the user images on there looked pretty good; no apparent visual noise, but those were probably all at the low-iso settings. It goes up to ISO-3200, which is fairly decent for low-light; the lens is only 24mm-60mm - I would personally look for something with a bit more zoom capability, was under the impression most modern P&S's went up to around 200mm; 10 mega-pixel isn't a lot for modern P&S, but there's probably no reason you'll need any more than that, unless you're planning on printing a lot of photos larger than 8.5x11 inches. Lastly, B&H lists this camera for $879, and amazon for $679, both of which are more than twice what I'd say it's worth - you can get a very decent DSLR for that price and have the option of buying better lenses, flashes etc. I'd say shop around, and if that's really the going price, look into an actual DSLR
So, based on amazon and B&H listings:
Pro's: Nice ISO response, decent user images seem to be fairly low-noise, 10mp is a decent size image; edit: just realized this thing is super-tiny physically - if you're looking for something you can throw in your shirt-pocket, this might be ok.
Cons: Price, you can easily get a camera that does all this and more for around $400 or less; the 60mm lens is not a lot of optical zoom, you will probably want more capability to get closer to the subject.
