From what I recall, you are a person that often asks for some form of `proof' when people make claims like this. Care to show me a comparison detailing for VPC is less resource intensive than VMWare (server, workstation or player)?If you're running Windows already, really, VirtualPC 2004 from Microsoft works really damned well for just some old DOS stuff. It's way less resource intensive than VMWare is in terms of memory, CPU usage, etc, especially for something so simple as a DOS VM.
After the initial install of the VMWare network cards, you do not need to disconnect from the network for a VM that uses NAT. At least that is how it worked in VMWare Workstation 5.5. But yes, installing VMWare Workstation/ Server requires at least one (1) reboot.It doesn't "infiltrate" your current OS with all the networking gumbledeegook like VMWare does - it doesn't typically force a disconnect from your network to install the NAT or bridging, etc.
here's a comparison of the two:It's free, by the way - as is VMWare Server, but that's the big one; VMWare Workstation isn't free and is better suited to individual workstations, obviously.
Or you can use Xen virtualization or KVM (kernel virtual machines), which may or may not be related.If you're running Linux then VMWare is the only game that really matters to be able to run other OSes in VMs;
That's an interesting...perspective.If you're running Linux then VMWare is the only game that really matters to be able to run other OSes in VMs;
