ninethreeeleven
TKer
- Jul 16, 2004
Okay I wasn't sure where to post this so MODS move it if you see fit. I have a ton of dynamat left over from my car (just cleaned my room, just found it). I would say about //runs to check/ a square yard of it (3ft x 3ft). It is the Dynamat "extreme" or what ever with the foil on it.
What if anything should I use it for on my comp. I think this stuff would most likely retain heat more so than the Ali case. I dont have the comp set up yet so I cant point out trouble spots.
So now that the case is bare is there any where you think I could put it that would help? Or should I just wait.
