Anyone here using any physical LeftHand stuff as iSCSI datastores? Seeing a peculiar issue as we are asked to build and integrate a fresh 5.1 environment into a LeftHand SAN consisting of 4 nodes, a pair of older P4500G2s and a pair newer P4530s. 10GbE connectivity all around between the nodes and to the Hosts through a pair of Cisco 4500x-32s. Of course SAN traffic is on it's own VLAN, and each Host has 2 x 10GbE paths set as Round Robin.
Looking at Performance tool the LeftHand management console, Disk Queues fly up to 40+ during the write phases of each test. And on in vCenter, Latency rises above 100-140 during write phases on the SAN volumes. Of course Local storage latency stays under 6.
I know there's a few LeftHand admins around here, any ideas? HP Engineers installed the new nodes and tied in the older nodes into the cluster, and calls have been made to them as well.
A QUICK test of Crystal DiskMark in a test Windows 2008 R2 VM yields the following numbers:
Mind you that these are EXTREMELY early tests to verify performance. IOMeter testing is running now.
Left Hand RAID 10 Volume
Left Hand RAID 0 Volume
LOCAL STORAGE - RAID1 - 500GB NLSAS
