Hi guys,
I have the following problem that appeared a couple of weeks ago. I use Left Alt + Shift to switch between 2 input languages for the keyboard. Everything was fine until recently when this combination stopped changing the keyboard language in IE8. I've found that now I'm able to switch the keyboard layout with Left Alt + Shift + Shift (in other words pressing Shift two times while holding Alt down) and also it seems that other people posting on the Internet have had the same problem. But I couldn't find an answer how to fix it. It's not the biggest problem but it is a little bit frustrating cause in all other applications it is working as it is intended, only in IE it's not... Any ideas what could be the cause for this?
