LED "reserved" Post codes for Award BIOS?
rpav
I have an Epox 9NDA3J 939 mobo. Does your motherboard supposed to always show something on the LED post code (if you have it)?
According to the index in the manual, my post codes correspond to "reserved" and always have a different random number everytime (but not any that have a meaning).
My motherboard seems to run perfect, but just a little curious of what is normal and what is not.
LEt me guess theyre in the 30-40 range yes? And it displays FF during windows loading?
If yes you installed USDM and have it set to report the temperatures to the display, so what youre actually seeing is the cpu temp, not the post codes.
NP, if you want it turned off rigth click your USDM icon, Setup tab, then Report temps to P80, It just says ff all the time though then, which is a bit dull imho
