I have a blue led out of some electronic device I busted because I want to mod it in place of my existing power LED on my case. I was wondering if this new LED will safely replace my existing power LED and whether or not there will be any problem using this larger (maybe even different style?) LED.
It does power up with a regular 9 volt battery if that helps. I guess the reason I ask is because of it's size difference. I don't know if this matters. It's only slightly larger.
So can I safely use this for a power LED to hook up to my motherboard? Thanks all.
