sn3ak3rp1mp
- Jan 25, 2006
My buddy is modding his Chieftech case right now and he's buying a fan controller. But he's concerned about the fans being too dim if he dials the speed down.
When I was modding my own case, I took my Antec Blue LED fans out into the garage to clean them off with the air compressor. To my surprise, when I directed compressed air at the fan and it started to rotate, the LEDs lit up! Really bright, because I'm sure I was rotating the fan at a really high RPM (that's what 70+ PSI will do to a fan blade).
So do the LEDs just rely on the rotation of the fan hub and use some kind of resistence to power themselves? Is there any way he can seperate the fan and the LEDs to give the LEDs constant voltage whilst reducing the voltage to the fan to slow it down with the controller?
He's using the Tri-Cool LED fans, in case it makes any difference. Linky
