Hello everyone.
So I had an idea.
I am making an acrylic case, and I was debating between using red or blue lighting.
Then I thought, what if the light would change color from blue to red? What would be a good paramater to use to vary the color? how about CPU temp!
So, does anyone have the slightest clue how one would go about this? I would think an arduino would be able to handle this quite easily, but would an arduino be overkill?
For example, at 30C core temp, the red light is at 0 pwm, and the blue light is at 255 pwm (full brightness). at 75c, the red light is at 255 pwm and the blue is at 0, and vary the pwm signal to the 2 led's based on core temp.
Thanks for any suggestions.
So I had an idea.
