LED backlight LCD looks washed out
RudeJoe
It seems this is the state of the technology - that LED backlit LCDs on laptops look washed out/ not enough contrast.
My old (now dead) laptop had the then common cold cathod (I believe this is was its called) backlighting technology and looked good. My desktop monitor is the same way. They also seemed to have a wider viewing angle.
I just bought a new laptop with LED backlighting and I notice that many colors, especially the blue text are very hard to read because they are so light. I went to the store this evening to compare other laptops to my new one and most seemed the same.
The specific computer I have is the Acer Aspire 5355 which has the 15.6" monitor.
Has anyone else noticed this? Does this seem to be the norm now?
Thanks
backlighting technology has nothing to do with it
a screen that looks washed out with an led backlight will also look washed out if you stick a ccfl behind it
your issue is that you bought a laptop with different screen characteristics than you are used to
I have had a few laptops (all CCfl and different brands) and now this one that's LED. The illumination on the LED is cooler (more blue) than those illuminated with CCFL.
But more importantly the LED monitors tend to look washed out in my opinion. If I tilt the screen at just the right angle (back) it helps to a certain degree but the hinge has a stop from tilting back more than a certain amount. If I'm slouching on the couch its fine but if I am sitting at a desk/table I can't tilt it back far enough to get adequate contrast. Just as importantly I don't like using the computer because of this, its uncomfortable to my eyes. My wife feels the same way.
I have been on the fence about this computer but I think I'm going to return it. I talked with Acer support and they want to service it. I don't want to be down for 2+ weeks and the potential that they say nothing is wrong with it and I'm out my 2 week return window at the store.
So, just as importantly if I get another brand/model I don't want the same issue. Are there brands that are known for there good image quality?
I do like the ultra slim case of this model.
The LED backlight isn't causing your contrast issue; the cheap panel is. If you want a brand with good image quality, get a Sony Vaio with LED backlighting.
