LED/ 3D printer switching power supply reliability?
matt167
I'm going to heat a small insulated building with a 5kw Chinese diesel heater. It's not off grid, and there is no 12v power source. But the Chinese diesel heaters seem to be perfect for this type of space. It's a compact oil fired furnace. Electric is just too expensive here. I needed a switching power supply able to supply 10A of power at ~13.5v. Anything over 12.6V is sufficient but I guess the glow plugs struggle below 13v. I could not find anything 'good' designed for a permanent installation type deal. So I bought one of the 3D printer power supplies that someone suggested be used with one of these heaters, and then ensured it had mostly good reviews.. I bought the 30A model vs the 10A model that was suggested ( heater pulls 8a when starting/ glow plug on, and 3a-3.5a while running )... will this thing be somewhat reliable for that use? If the heater looses power it's not a fire hazard but the extra heat will fry the control board.
I did think about modifying a UPS power supply with power leads but I wasn't sure if the charge controller could handle it, and I thought about putting a 12v battery in a box outside on a charger. But a 10A "Automatic" charger can still boil a battery
I'd be helpful if we knew what "chinese heat machine thing" you were talking about, we can't really give you a suggestion without knowing exactly what you have.
With the battery voltage requirement and current usage, it sounds like its for an automotive application, something which a 3D printer power supply isn't exactly suited for since the voltage is too low. If you want to go that route, I'd get a boost converter that can bump the voltage up to battery voltage if the heater doesn't tolerate 12v properly.
It will operate on 12v but people say the glow plug will struggle at that voltage.. They use 8-10a at 12V when starting, but use 3-5A otherwise. The power supply I got has an adjustable pot for voltage. If I can get it above 13v it will work best I think
Why not just use a generator? CHP gen installs are great for heating and providing electricity.. which you can use to heat if need be. A slow speed Lister or similar (they are harder to get in USA but anything similar will do) is probably a better option no? You're already burning diesel.. why not make it work for you.
But yeah if you need a reliable PSU, meanwell is the way to go. Only time I have had them fail is using their lowest grade ones and severely over-driving them. The expensive submersible mil grade/alu frame and open frame ones are fucking rock solid.
The building is wired for 110v as it is, so a generator would be unnecessary.
I turned the power supply up to 13.77v and it held stable with a small load. Going to run with it for now,
