OK they only problem with my Serta chair is "peeling leather" on the Arm Rests. I'm going to buy a Roll of this stuff I think it will work out OK. Not sure of the texture.
The leather tape actually works well, my kids gaming chair has quite a bit on it and it's holding up better than the pleather it came with. Duct tape will degrade fast if your body oils are on it all the time or it is getting pressed on and whatnot.
I changed the tape around on my lunch break it's alot better except it looks like The Batmobile cover. I think the Gorilla tape will last the life of the chair it's thicker than the cheap stuff. Would like to get a Xchair or something.
I just picked up some Strap on Memory Foam Arm Rests I took off my old Arm Rests which were really rough after I removed the tape.
I just hope they don't slide around if they do I can always use some Velcro I suppose. The Duct Tape I used those for about 4-5 days and you guys were right
I had to unscrew the padding on my Serta with a Allen Wrench which destroyed the Arm Rests totally so I hope the Amazon one works out better than the Duct Tape arm rests.
