One of my summer goals this summer while on break is to learn Exchange 2007 and get it going. My "learning/test" server consists of the following specs:
2 AMD Opteron 2218's
4 gigs of ram
500 gig SATA hard drive (should be a SAS drive I know)
I have Windows 2008 Enterprise installed for my base OS and created a VM with Hyper-V to install Exchange on. I gave the VM 2 processors and a gig of memory Obviously I know its a bad idea to virtualize Exchange but this for my learning purposes only.
My question is, besides the recommended specs, what specs have you guys found that Exchange runs best on? I plan on putting another 4 gigs of ram into this server soon after my next paycheck and then give the Exchange VM more ram, probably 3 gigs worth. Right now the Exchange server with all the roles installed is killing my memory and wants more.
Also, I have a spare P4 computer with 512mb of ram laying around that I plan on using for the Edge Transport server. Would this PC be enough for the Edge Transport task?
Also, you guys know of any sites with good info on Exchange 2007?
4 gigs of ram
