Learn More about how Spectre and Meltdown Work
FrgMstr
Just Plain Mean
Staff member
Let Jon Masters, Computer Architect at Red Hat, help you understand just exactly how Spectre and Meltdown work. While he had to plow through his 90 slide presentation on stage in 45 minutes, he has been nice enough to give us direct access online. However you can click through those as slow as fast as you wish. The PDF entitled, Exploiting modern microarchitectures: Meltdown, Spectre, and other attacks, is available here. Thanks cagey.
Today's lecture will cover the following: Introduction to microarchitecture as implementation of architecture In order vs. Out-of-Order execution in microarchitectures - Caches, virtual memory, and side channel analysis - Branch prediction and speculative execution - Spectre and Meltdown vulnerabilities - Mitigation approaches and solutions - Related research into hardware
That is a pretty good breakdown and helps explain why this is an issue with the current architecture and can only be fully fixed with a change to the architecture. It seems they also point out, that change could be simple, although how it will invariably effects performance remains to be seen. It explains how the current patches or "fixes" aren't ideal, especially the microcode. There are serious costs to performance/operation using many of these fixes.
It also does a fairly decent job of explaining the complexity and difficulty of the attack. These attacks are not easy to pull off, however, once you learn how to execute it on a particular system, it can be repeated with more confidence.
