natermeister
- Dec 26, 2005
I just got to testing my w/c setup, for the record it consists of:
Thermochill PA120.1
D-Tek Fuzion V1
Laing DDC3.2 with Petra's top
Swiftech MCRES
I'm getting very slight leakage, but only on the fittings of the reservoir and the pump. In other words, only on the plastic parts. The fittings I'm using are not supposed to require teflon tape (they have a sealing ring and a secondary o-ring). They're industrial grade quick disconnect compression fittings and I'm using proper tubing.
I tightened them up more, and it appears that they aren't leaking anymore. Still, I ran the system in for 72 hours with only power to the pump and it didn't leak. It seems to take some period of days to weeks to start leaking. Anyone have any ideas? I've thought about laying a thin bead of silicone around the fittings to help staunch the leaking.
Thermochill PA120.1
D-Tek Fuzion V1
Swiftech MCRES
