Leaking Hydor L20?
ezrem
Hey watercooling guys,
I have an Asetek Waterchill that I installed about 6 months ago into one of my PC's.
The other day I decided to clean dust out of my machine because my temps were a few degrees higher than normal.
Imagine my surprise when I found the reservoir only barely containing any amount of water at all, with a small puddle of water and lots of evaporated remains surrounding the pump.
Thankfully, this did not do any hardware damage.
In any case, I took the Waterchill out of the machine to do some testing to find the leak, and ended up pinpointing it to be at the pump inlet. When I would run the pump it looked like water was even leaking out around the TOP (!) of the inlet. Note that I do not mean the out connector on the top of the pump, merely the upper part of the in connector on the side.
Anyway, is this something that I can fix with a little bit (or a lot) of RTV silicone around the inlet, or should I just get a new pump?
