Leaking buldging caps...new mobo time...
Lunas
So after getting my new corsair hx520 powersupply installing it and installign the new agp videocard i got for my old epox 8k3a+ i discovered that 2 of its caps were showing problems... Now i know i could just simply replace the caps but i would rather not... The machine in question is still working right now... and still stable i think...
Well i am now taking suggestions on how much of it i should replace... So far what i have seen is my choice of socket A boards is limited to 1-2 diffrent ones and my selection of agp equipped boards is also limited...
The easiest thing to do i think is to post a list of components i want to keep
1. ls-120 floppy...
2. 3 ide hard drives totaling 376 gig
3. 2 ide cd roms
4. 1 gig 2x512 333mhz ddr ram
5. xfx 6800xt gddr3 256mb video card agp...will be willing to step up to pci-e but only if the replacement is better than what i got...
Various old pci cards that could be removed...
6. Sb Live! x-gamer orginal version...
7. hauppage tv tuner that stopped working un expectedly well video did fm tuner still works...
8. usb 2.0 card i need atleast 6 usb ports... no hubs...
9. 3com 905c 10/100 server card... I would like to keep this unless the onboard is alot better
I would like the board to be based around a 939 or AM2 socket and the max ammount to spend is 400 i would prefer it as low as possible and no sempron processors
Why not pick up a newer Epox board from newegg if they still have them...
It may be cheaper to have someone at badcaps.net recap the board for you with some Rubycon caps...
well this is an excuse to upgrade but i have considered it. I would prefer to get either a 939 or am2.
nobody has any suggestions? my only choice for newer epox boards are newer sockets or 70 bucks to stick me with another socket a to run my 2400+ in...
One of the reasons no one is chimeing in is because all of you drives and cards are now near extinction. Nearly none of the newer boards has a agp, most if not all boards want sata for the Hd, and most are only coming in with 1 Ide for the optical drives.
56.00 sempron
http://www.newegg.com/Product/Product.asp?Item=N82E16819104305
62.00 MSI Mobo
http://www.newegg.com/Product/Product.asp?Item=N82E16813130056
132.00 Corsair Xms ram
http://www.newegg.com/Product/Product.asp?Item=N82E16820145566
56.00 /ea Wd 160gb 3.0 sata
http://www.newegg.com/Product/Product.asp?Item=N82E16822144203
So you would be looking at 306.00 + shipping, add 56.00 for second HD and you have an up to date system that is upgradeable to dual core and still under 400.00.
My .02
gwarren007
Well personaly my plans were socket 939 or am2 drop all but the usb 2.0 card sell my new video card to my brother who just upgraded to a 939 with agp.
While im getting new parts i pick up a ide controller for about 10 bucks i looked that is bout what they cost on the egg pick me up another 250 gig drive which i would use to replace my 46 gig ibm death star. I would then run my 250 gig drives off the card or sata... though i am also looking at new optical drives... 16x dvd and a 4x4x12 dvd burner... yeah those are getting extinct too... 60 bucks gets me a new ide burner and a sata dvd/cdrw combo drive... I only need to drop 1 ide device from my system to brign it down to 4 devices...
Ill post what i come up with here then people can make suggestions on that...
