Leak Test Help
phatjedi
Got my loop done, everything is hooked up and I want to do my leak test. How do I power my pump with power supply? I don't want to power on video card and other fans, just the pump. Can anyone tell me how to do this? I have a Swiftech MCP655.
Thank you
Just don't connect anything except the power to the power supply, the motherboard wires shouldn't plug in the psu for leak test. To jump start the PSU read this thread so you can see the image.
Pull the main 24 pin from the mono and jump the green wire to any of the black wires. Plug in anything you want to be powered any turn on the psu with the switch. Btw... quick Google search would have netted the same answer.
Thank you, that is exactly what I was looking for!!!!:D:D:D:D
