So I did the standard 24 hour leak test with tissues wrapped around all my connections and nothing... Been running the computer for about 2 weeks now and got some random freezes and restarts but didnt think had anything to do with the watercooling. Heard a garbling sound and checked my res and it was way down.... investigated closer and there was barely a hint of red dried liquid... thought ohh shit.
So checked it out further and my intake port on my swiftech gtz was leaking, i guess i didnt have the worm clamp tight enough or in the exact right position and a little bit of water slowly got through the clamp and builds up and then drips. After investigating further I actually had gotten quite a bid of liquid all over my computer.. On the sound card vid card all over the mobo in the sockets... Just cleaned out everything with 91% alcohol and letting it dry overnight now.
So if the liquid caused the freezing/restarts thats all it did as I just pressed the button and was back in business so nothing damaged.
Long story short, does distilled water work, sure but im glad I bought the feser as it might have saved something, maybe not. At least since it was colored when it dried up I could see that it was leaking, otherwise would have never known even upon investigation.
