freddiepm61
- Oct 19, 2004
I have been looking around, and if I am not ocing, should i get:
6800 ultra stock cooler card, or leadtek card?
i will be running in SLI, and i have seen temps on some systems of like 90C...
If i have 2x120mm fans, and a 92mm fan blowing onto the cards and proc, and using the a8n-sli with lots of space in it, will the standard cooler be enough to keep it below 65@ load? or will i need leadtek?
because, i am thinking that being ay 75/80c at load will not make a gpu last for 3 years (which is how long i have until next upgrade....)
thanks
f
thanks
f
