chisaipete
- Jan 3, 2005
I'm running a WinFast A400 TDH (Geforce 6800). It's great! But one drawback, the fan is too loud. It makes a quiet screaming sound...I'm going to pull out the card and do a more in-depth cleaning of the fan, but I have done so in the past, and it's still the loudest fan on the system.
Is there a way to mod or replace the fan to quiet it down? I really like the massive copper stock cooling...unless you can convince me that I should sacrafice it's weight for a better cooling solution on AIR.
Thanks,
-Chisaipete
Thanks,
-Chisaipete
