Leadtek and MSI 6600 GT
v1rtu0s1ty
Hey guys,
I'm back. Upon seeing a lot of horror stories about XFX 6600, I decided to change my selection. And now, I've got 2 brands left, Leadtek and MSI for 6600 GT. I've read both cards are good. I spoke to MSI about the video-in, they told me that they don't have any driver for Philips SAA7108 chip for linux. :(
Anyways, that's not a stopper. So guys, which between the 2 should I really pick?
How long is the warranty on Leadtek and MSI, anyone please?
Thanks,
V1rt
Leadtek between those two.
MSI isn't bad, but don't be fooled by all the damn software and games you get. Have read just as many horror stories about them arriving DOA or shorting out very quickly.
I would really suggest looking at eVGA - great product from a great company. Plust they have a program which you can save up for a better card from them. So once u buy the card, within 90days, you can trade it in for let's say a 6800gt and just pay the difference.
Also check out BFG, a little bit more expensive, but you get a lifetime warranty, Dual DVI, and it's Overclocked out of the box.
I have an MSI, and i'm very happy with it, games are great, oh and I love VIVO. The capacitors do look like cheap chineese ones. I haven't seen the Leadtek's but they are probably Japaneese. I think Leadtek puts more "quality" parts in their product, but I definetly would not say MSI is bad, at all.. I say, get which ever one is cheaper as both products are great.
I still say that among the two we looked at, the MSI looked better cooled. But, I admit LeadTek does tend to put in good parts... I mean, this thing could apparently ALMOST reach GT specs... The core could reach Ultra specs if it had enough power (in fact, it could be put in an Ultra and only an OCer would know the difference...) and the memory is just below what a GT runs at stock in AGP apparently...
I don't know, I guess memory cooling isn't horribly important. When I put heatsinks on my old Radeon 9600 Pro, my memory ocing went up something like 5MHz... I just figured if nothing else at least it should make the thing last longer... (I'll never know now since a surge or something damaged the thing.)
Go with the LeadTek I suppose.
Yes, like I've told you the first time, go with the Leadtek card. They tend to make good quality cards, and I am very pleased of my Leadtek 6600GT.
And well, it still is very quiet.
And the memories being at 900, most of the cards on AGP have them Nazo. I can give another example PNY, that has the same specs.
Though, there is that ASUS 6600GT that has the memory at 1100 if I remember correct, on AGP. But it doesn't worth the price, because in the same money you can get a 6800.
My opinion ...
Anyway, go with the Leadtek, I guarantee for them.
EVGA>BFG>Leadtek>MSI>XFX
(The evga is the best one do to there step up program, which is IMO a VERY good idea)
Ok guys, I'm getting Leadtek on Feb 5. That's the day, I hope, newegg will have it. Oh btw, I noticed that there is a Molex 4 pin power interface on that card. :) So it seems that it really needs energy. Here is simple situation. I have a mid tower at 300W and would like to replace my 300W. As I am not good in researching in which brands for power supplies are good, can someone send me a link to newegg for the power supply, ~400W to ~450W and that it is not too expensive. I also don't like ps with neon lights.
Thanks guys again for all the help :)
350W MIGHT be sufficient if it's a good quality one, in case you are on a tight budget here.
That said, this is what I'm using:
http://www.newegg.com/app/ViewProductDesc.asp?description=17-153-006&depa=0
It's a ThermalTake 420W PSU for only $39. Most will recommend that you get Antec or one of those, and usually they cost more. All I can say is this thing has been doing fine for a long time for me, despite the fact that it's plugged into a dirty line (I can't do anything about that, this house has crappy wiring.) Not to mention that I have two rear fans, one 4" side fan (albiet running at half capcity -- eg plugged into the -5 and -12V lines to get 7V somehow) as well as two HD coolers in the front and a single front case fan. Almost every PCI slot is taken, and most of my USB ports are used. No neon crap or anything, but, still, I'd say that all this stuff makes for a pretty good test of stability on an OCed system...
EDIT: See? Lol he posted too fast for me, anyway, most people will indeed. In fact, people seem to not particularly love ThermalTake as it doesn't have the best reputation for PSUs. I think this PurePower series has potential though. My dad got one of the newer, more powerful ones, and it looks like it was designed for the overclocker.
The power requirements of these cards aren't really TOO bad, just the AGP doesn't quite provide enough for them to get by with any stability on. A decent PSU should do the trick.
i heard that leadtek get their 6600 series made by foxconn.. i might be wrong but anyone seen the quality on leadtek 6600?
A buddy of mine has a Leadtek 6600GT, and while we didn't pry off the cooling solution to take a look at everything on the card, what we could see form a visual inspection was incredibly positive. There were decent parts, and the fan on it is reasonably quiet. All in all, leadtek is a great company, in my experiences, to not only buy from, but if you have to RMA stuff to (I had an OLD 4200Ti that was 2 weeks out of warranty, and they were more than happy to take it back, which is a huge plus, in my books).
