MasterShake
- Feb 28, 2005
Hi. I have been having problems ocing my Leadtek 6800gt. I'm currently using a bfg 6800 ultra oc bios on it and have used the leadtek gt bios with a .1 increase on the voltage to get higher overclocks. The problem is that sometimes it will freeze up and become corrupted and sometimes reboot. I can usually get it to run aquamark and sometimes 3dmark a few times and it shows a big increase in scores and games usually run fine for a while. But if I play for extended periods of time or loop a benchmark a few times it will usually freeze and show a corrupted screen. It looks like when you would not have an old nintendo game in all the way or if the connection was dirty. I have tried all sorts of drivers and read the forums about the 6800 problems, but I don't have problems with freezes every few seconds or anything like that, just hard locks when I overclock higher. I think it is either the power supply, possibly the card, or heat. The leadtek has a very nice large heatsink. The problem could be my case though. It's a Silverstone tejmin 6. It's one of the ones with the reverse motherboard tray and it keeps the cpu components separated in a windtunnel, but it uses the power supply fan for the exhaust and an 80mm fan for the intake to cool the pci and agp cards as well as the 3 hard drives I have running. I currently have a 400 watt sparkle/fortron supply. The motherboard monitor says the 12v is very very low, but I don't think I trust it. It does fluctate a little however. I'm looking at getting a seasonic s12-430 supply with a 120mm fan, but I can't really afford it right now and an nv silencer 5 would be more affordable. I don't want to buy it if that's not the problem and if it's the card or something else that's bad. Plus I would void the warranty and not be able to get a replacement. I have had this card running at 445/1200 before, and I really want it to be able to run stable that way. I hope you guys can help. Thanks.
