leadtek 6600gt wins!!!
If heat is an issue get the Leadtek, they've been around for a while so I doubt they'll pull a 3Dfx and dissapear one night.
well look at the heat differance is like 30*C on a full load between that one and the gigabyte graphics card and i am going to have 2 graphics cards later on and wont that produce alot of heat to worry about?
They will all use the same amount of power, however the different temperatures of the cards is due to the different cooling solutions the manufacturers have used, if one of the cards is 30C cooler, it means it's shifting that heat away from the core well, however, where it's putting it is worth knowing, if it's dumping it in to the case, then you're going to need some good case cooling to handle that extra heat.
good idea. best cooling solutions can = best OC's and enlongated core life.
~Adam
