Leadtek 256MB A400GT question
Evoken
I want to buy a Leadtek 256MB A400GT today, but i'm unsure if my PSU is powerful enough to run it.
I have a 350w antec PSU, with 3 HDs and a p42.8 running off it. I REALLY dont want to have to buy a better PSU.
so.. would it be a mistake to buy the it? perhaps i should get a 128mb 6800 version that doesnt require tons of power?
A 350watts Antec psu should just about be good enough for a GT. I believe this card uses just one molex power connector, unlike the ultra which uses two. I got the 6800nu version working on a 300watt Thermaltake psu without any problems, so the GT should be fine on a 350watt Antec. It may be an idea to check your 12 volt rails, anything around 15amps on each should be fine. My advice would be to try it and see!. If you do experience problems go for an Enermax Noisetaker psu, this superb psu keeps the case ambient temp low and it runs silently.
Abit BH7 (Intel 845PE)
Intel 2.5 ghz P4 533 FSB OC 3ghz
512mb 2700 DDR
256md 3200 DDR
Leadtek Winfast 400 TDH 6800 OC 390/835
Creative Soundblaster Audigy 2
120gb Hitachi SATA 150 HDD
30gb IBM Deskstar 7200 HDD
Plextor CD-RW 40r-40w-12rw
Pioneer CD 40x
Pioneer DVD 16x
Enermax 420 Watt Noisetaker AX
+3.3V@32A, +5V@36A, +12V1@15A, +12V2@14A,
-12V@0.8A, +5VSB@2.5A
19" Mitsubishi Diamond Pro 900u
Logitech Webcam Messenger
Speedtouch ADSL Modem 1024dl/512ul
Windows XP SP2
why do company's rename 6800's all the time? i mean, seriously, it just add's extra strain to someones brain, WHY leadtek/asus WHY!!!
to provide distinction. leadtek has the right to do it with the 6800 series due to the cooler. asus just sucks and does it because they can.
