LCDs look weird to me...
jamezzz122
Well I just bought my first LCD and it is a Sony SDM-HX73...
On the LCD, it looks sort of unclear to me...I have been using CRTs all my life so am I jus tnot used to it?
The edges don't look smooth...
The video card is a 9800pro BTW...
What do you think it up?
are you using DVI? ClearType?
In my experience LCDs are very sensitive to resolution. If you aren't at it's native resolution it could be blurry.
I changed it to it's native resolution once I used it...
Not sure...How can I check and which is better?
You think what I am experiancing is normal?
James, since you gave no info at all about the monitor, I searched for it on several monitor reseller sites----and no one sells it. Does it have a VGA connector or DVI connector? Give us some info from your owners manual.
http://www.amazon.com/exec/obidos/tg/detail/-/B0000DANCU/002-9333148-0493612?v=glance
Amazon.com says:
"Analog and digital DVI-D signal compatibility, both cables included"
If you plug it into the blue port on your video card, you're using analog. If you use the white port, you're using digital. The white digital port will provide superior image quality. If your video card doesn't have a white digital DVI port, it may be worth upgrading to one that does given how expensive the monitor is.
Will it really make that big of a difference to switch to DVI?
I've noticed that too, though I don't own an LCD monitor, every time I use one text seems very wierd to me and things just don't look right, however I never have that problem on CRTs.
Yep that si what is happening to me...
I am using the blue analog port in my 9800pro..
How would I go about upgrading so I can use the white digital port?
All it should take is changing the cable between the monitor and the card. There's a good chance that a DVI cable was included in the box.
DVI is better, I can tell a difference.
Try this:
right click on desktop>Properties>Appearance>Effects>Use the following method to smooth edges of screen fonts:>ClearType
Try this:
Hmm, may have to try this. My screen is fine, but sometimes the text is hard on my eyes. Thanks,.
My laptop doesn't have clear type, and when I first got my LCD (NEC 1980SX) I used a VGA cable. I had no problems at all.
Now I'm on my desktop using DVI and have cleartype enabled. It's very crisp and pleasing to look at for text. It's possible you have bad connections in the VGA cable, or elsewhere in the connection. I don't really think it should be "weird" in any way.
I went through 2 LCD's. I forget the brand on the first one, but the second one was an Ag Neovo that I've heared people from this forum recomend to people... I took them both back due to blurry text. Neither of them had a DVI connector, but still, you'd think they wouldn't be incredibly blurry with normal VGA connection. And no, it wasn't my rig, I tried both of them on my dad's rig with a high end graphic card in it, still burry...
I have yet to see a desktop LCD monitor I like. Sticking with my triple CRT's for now...
The weird thing is, though, my laptop is crystal clear? :confused: Who knows.
Bad cables?
The reason the laptop is gonna kick ass is because its just like DVI, totally digital connection. If you had DVI it should be the same way.
