LCD Upgrade from crt for gaming. Help!
Willso
Hello all I have been long trolling these forums but this is my first post. Right now I have a 19" Viewable sony Multiscan G400 crt monitor. It has been great and can run really high resolutions. I am thinking about upgrading to something slimmer and bigger screenwise without breaking my wallet. I have a 19" viewable so I want to go to atleast a 22" or bigger. I have a 42 inch 720p westinghouse that I can hook to my computer but obviously cant get as sharp as I want. Also the refresh rate or response time I think is a little high because when I move my mouse I can notice a small lag.. I do alot of browsing and playing half life 2 and wow ect. Does anyone have any good recommendations for a new screen in the $300-400 or less range? Remember I want a 22" or higher LCD preferably black.Im guessing also with a good response time and good for gaming ect. I am running a Geforce 8800 GTX vid card so I want it to be able to shine :)
Thanks!
Well, for $300-400, you'll have to stick to TN panel monitors. The HP w2207 is a good choice, 22-inch widescreen.
You're not really going to find 24-inch monitors for your given price range unless they're real cheapy ones, which you shouldn't be getting anyway.
Samsung 226bw
There is a huge thread about this monitor on the first page, and I strongly suggest reading through it, even if it is briefly.
It is a TN panel, and the drawbacks are that is has worse color reproduction than other types of LCD panels, and they viewing angles arent the greatest. I dont know about other people, but when I sit at my desk and Im always right in front of my monitor. As far as the color reproduction goes, well, I have only used TN paneled LCDs, so I cant really comment on that.
Another thing is that there are a few different types of panels, notably A and S types. The S panels are supposed to be far superior to the A panels, but I dont even think this is an issue anymore because from what I have read recently, Samsung has decided to only use S(Samsung) panels from here on out. Im not sure if this is true or not.
With the politics aside, it seems to be a great monitor for gaming.
Check this article for comparisons of the A and S panels.
http://www.behardware.com/articles/667-1/samsung-226bw-a-and-s-series-the-verdict.html
A quote from that article:
Should we regret having bought an A version and would another screen have been better? No. The 226BW, whether it’s an A or S, is still above the rest.
