LCD tearing during gaming. Solutions?
Scolecite
I have a 2005fpw. I noticed that during games I get tearing.
Now I know that this is mostly due to not having V-sync enabled. But have you ever enabled V-sync with CS:Source? If I do It totally fubars my framerate like to unplayable. I uncheck V-sync everything returns to normal. I dont get it and I guess thats a specific question about a specific game, but....
What does triple buffering do to help or hurt tearing?
What does a 60Hz refresh have to do with tearing?
~thanks~
What does 60Hz have to do with tearing?
I think there are two reasons:
1) Due to the shortened interval between frames, your eye has more of a chance to pick out the tearing in the image.
2) The time between each frame is longer than at higher refresh rates, so different parts of the screen affected by tearing will be showing information that is skewed farther apart from one another in time. This results in more pronounced tearing.
Combine the two above, and you get mich more pronounced tearing at low refresh rates. (This is the way I understand it, I could have something wrong here)
I've ordered the 2045FPW monitor, and I'm awaiting its arrival. This issue has concerned me a bit because I tried playing HL2 at 1920x1200 resolution @ 60Hz. With VSync on, I noticed my framerate dropped alot more than with VSync off, and I too noticed really bad tearing when VSync was off :( I don't notice that nearly as much at 85Hz.
I'd like to know about this triple buffering stuff.
Triple buffering circumvents the frame rate divider problem under vsync + double buffering that can cause crappy fps, by adding an extra frame buffer in between the frame being displayed and the frame being drawn, at the expense of extra vram.
It has to be supported both by the videocard and the game engine to work, most games do support it (although for some reason you don't always get the option to enable it in the games own menu, sometimes you have to go into the config files or worse...).
If you use vsync you should always use TB if you can for best performance (vsync+tb gives the same minumum fps as no vsync, although obvious vsync caps the max fps).
I believe that CS:S has some kind of problem with TB, I read somewhere that in HL:2 TB automatically switches on when you select vsync, but that CS:S can't/won't do the same thing, possibly because of multi-player network synchronising type issues.
