LCD suppose to do this?
Daedro
Hey, I've got a Samsung SyncMaster 931c. When I scroll really fast up and down websites fast it looks like it takes everything a millisecond to redraw, so it KIND OF looks like a VERY LOW flicker, NOT a flicker like the monitor resetting - dying. When in games like WoW its very noticeable. It does it on these forums a little but it's hard to notice. If you look on the left and right background of this site you immediately notice it (if this is standard for LCDs): http://mmogm.com/ Over top of the diagonal lines this example shows orange oppositely diagonal lines. Weird.
Anyone else with LCD experience this? Is it just my model? Thanks!
Hmm, the 931c has a TN panel, so it shouldn't be suffering from ghosting. Can you give more information, like which graphics card you're using and whether you're using a VGA or DVI connection?
Radeon X1950 Pro, which has been running good, besides when it bugs out a bit when I run WoW and a movie on the other monitor.
It's dual so I can use either, and last time I checked it didn't matter which.
Up to date drivers, SP, directx.
I figured it was the monitor when I got it, as it put off a smell the first few weeks after I got it, but it's been somewhat 3 months and it's fine besides 1 always green pixels on the left I hardly notice.
Might be compatibility.. said I couldnt use the colormaster software because of my video card.. or drivers so I'm using windows default.
do you have the monitor hooked up to the video card through a DVI or through VGA??
DVI will give you the best quality, if you are using VGA? this might be the problem?
