mayakindaguy
- Jan 28, 2004
I am currently running dual monitors for Maya.
A 19 inch ViewSonic A90f+ and an old 17 inch HP Pavilion as my secondary monitor.
I'm seriously thinking of getting an LCD to help with the eyes and the long hours in front of the computer. My budget is around $1000 USD.
The thing is I've heard quite a few negative things about LCD and 3d work as well as gaming, but I'd really like to get a 19" or 20" LCD, but don't know if the cost is justified. I've heard both good and bad things about the DELL 20 inch as well as the Samsung ones. Don't know if you guys could recommend specifically what will work best with 3d work because all I have to go on is basic reviews which has the DELL at the top. (however, consumer reviews don't seem to rate them as terribly high as they are on pcmag and cnet.) I've never experienced ghosting, but I think that I'd be quite annoyed at paying around $1000 for an LCD and have to put up with that or any dead pixels.
My second question is whether it was possible to have my viewsonic or hp as the secondary monitor and the LCD as the primary. I'm not sure whether there are any conflicts with such a set up. Just wondering because with my Quadro FX 1000, you have to use a horizontal spanning desktop that spans both monitors to be able to have right click menus come out on the secondary monitor. Would have a dual setup with a CRT and LCD be best because I will have the best of both worlds or should I be saving up for 2 LCDs?
I guess that's all I can come up with now.
Thanks
Thanks
