LCD question
I got the 912N Samsung and i want to know if its really a good LCD cause on some games i got some gosthing... well this is its specs
please help me out to know why do i have gosthing... :confused:
Panel Type a-si TFT/PVA
Size 19"
Pixel Pitch (mm) 0.294
Brightness 260 cd/m2
Contrast Ratio 800:1
Viewing Angle (H/V) 170/170
Response Time (ms) 25
Aspect Ratio 4:3
Interface Analog
Frequency Horiz. Rate (kHz) 30-81 (Analog)
Vert. Rate (Hz) 56-75
Bandwidth (Mhz) 140
Resolution Native 1280x1024
Colors Supported 16.7 Million
Signal Input Input Video Signal Analog RGB
Sync Type Separate H/V, Composite H/V, SOG
Input Connectors 15pin D-Sub
Plug and Play DDC 2B
Power On/Working (Watts) 38
Wall Mount VESA® 100mm (optional)
Cabinet Color Front/Back Black
Available Colors Black
Dimensions (W*H*D) Physical (inches) 16.4 x 16.7 x 7.5
Packaging (inches) 20.0 x 19.4 x 5.9
Net Weight Physical 12.1 lbs
Packaging 16.5 lbs
Features Special Built-in Power Supply, Narrow Bezel, MagicTuneTM, MagicBrightTM
nice, u have even given specs of its box and its weight. :D though wont help here.Have u tried changing ur input from D-Sub to DVI.
Also put highest refreash rate possible via the control panel.
Two reasons you have ghosting:
1) No DVI input.
2) 25ms response time.
^ what he said
ghosting will never completely go away on LCD's until they reach the nanosecond level
but as the response times get better it will be noticed less and less
