LCD or CRT for high end gaming
FanATIc
Basically im in the market for a new monitor. I'v always said i prefer CRT over LCD especially after hearing about problems with ghosting since its main pupose will be gaming. But the DELL UltraSharp 2005FPW is damn sexy. My other option that i'v limited myself too is DELL P1230 22" CRT. Now my question is how demanding on the graphics card is it to play in the native wide screen resolution of the LCD with maximum details? I ask because i will be buying a dual graphics card setup soon and i dont want 1000 dollars of cards to go to waste if one card is going to be enough. Thats where a CRT would obviously be better since i can move the resolution higher which will obviously be a reason and a need to use 2 cards. Basically im curious if the monitors resolution limitation would be a main reason not to invest in a dual card computer.
Anyone with this monitor or one simuliar find that the resolution puts quite a bit of stress on the amount of options you can enable, or no? Obviously the answer to older cards will be yes, but how about this years Geforce 6 series and Radeon X8 series. Advice, or help appriciated.
Good CRT is usually much much cheaper...but can't fault you if you want to ante up for a 2005FPW.
A single 6600GT or 6800GT should be plenty. SLI is mostly useless for the moment.
price didnt really matter, either way, CRT or LCD, it will be $600 or so. Problem is that dual video cards only show serious gains at high resolutions/settings, just dont want to spend all the money for 2 cards and find myself handicapped by an LCD's resolution max. I have no idea how stressing the 1680x1050 is.
gah, this section filled with mimes? Bump.
Suppose i could get a 2405FPW. Though im on an 18 CRT right now, I think the jump to a 5 inch bigger screen would make my head explode.
1600x1200 = 1920000 pixels
1680x1050 = 1764000 pixels
1280x1024 = 1310720 pixels
But then take into fact that widescreen (16:9) aspect ratios tend to be a bit more demanding and games aren't as optimized for them, and you have a load a bit over that of running at 1600x1200.
If you care at all about ultra-smooth frame rates at all, stick with a CRT.
I've been using a 2005FPW for a while now, and while I am perfectly happy with its quality as far as LCDs go -- it can in no way compete with my old CRT when it comes to games.
A friend who recently upgraded his computer has really driven this point home for me. While his system is still slightly below mine in terms of power, the actual visual experience he gets with his CRT is so much smoother, precise, and lag free.
After playing on his rig, coming home to the LCD is a bit of a tough pill to swallow. There are 2 main sticking points:
1) anyone used to playing games at higher than 70 or 80 frames per second will be able to spot the difference right away -- due to latency and refresh rate issues you never have that ultra-smooth feeling with the LCD.
2) delay in response. Things just don't feel as precise because there is a very slight but noticable delay with regards to your movement in the game world.
I have both, and the LCD (2001FP) is great for text and such, but for FPS no way. Way too blurry in fast action combat. If that's the type of games you play, stick with a CRT.
water1 said:
What about the 8ms LCD's ? Aren't they pretty smooth ?
I have a IBM P275 CRT and a Hyundai L90D+, I play games on both...but I must say I enjoy playing on LCD better:
positive:
1. it's brighter
2. easier on my eyes 60hz @ 1280x1024 vs 85hz @ 1600x1200
negative:
1. some ghosting even though it's 8ms when there is high intensity...although very subtle, you will notice it if your used to playing on a good crt
Ive played all my games on my Hyundai L90D+ and I simply cannot tell any kind of ghosting. YMMV.
I think basically choosing whether to go with CRT or LCD at this point is all about 2 things, user preference and cost.
I used to be all about CRT's and in a way I still am. I realize that technically they will always have higher luminance, pixels per square inch, higher resolutions per size etc. However I still finally decided to make the leap to LCD about 3 weeks ago due to a few reasons.
First weight; lan parites, or moving my computer arround, nuff said.
Lack of glare, and easy on the eyes; my p95f+b while I love it has been killing my eyes while reading text for long periods of time, my lcd does not.
Widescreen; in order to go widescreen on a crt I would have to get a 24" which would be great if I could afford it... in otherwords widescreen availability at my price point.
Perfect geometry; one thing that is difficult on a CRT is getting perfect geometry, things like having to mess with the parallelagram thingy, or horizontal, and vertical sizing for different resoultions and Hz settings really started to annoy me. With a LCD just plug in the DVi and you're set, none of that bullshit to mess with.
Finally the other reasons why I went to LCD is because I finally think that the response time is quick enough. 12ms grey to grey is plenty fast (not to be confused with overall response time), and when I saw my friends monitor, and did some quick tests like Doom 3 (high contrast really dark) and didn't see very much motion blur (not to be confused with ghosting) if any at all, and I was sold. It just looks so damn good. Motion blur isn't even a problem for me at all on any of the games I play, and yes I was a hardcore CRT guy for sometime, but then again it still comes down to user preference.
Anyway, that's my story and my reasons, there are still plenty of reasosn to stick to CRT's like some of the reasons I listed earlier. In addition they are still cheaper per square inch, and are prefered if you do a lot of video or picture work.
I just found that for me, right now LCD's are a better decision, if for nothing else other than looks, deskspace, and being easy on the eyes. Sometimes it's just those simple things that put it over the edge.
I just found that for me, right now LCD's are a better decision, if for nothing else other than looks, deskspace, and being easy on the eyes. Sometimes it's just those simple things that put it over the edge. So now I'm the proud owner of a 2005fpw, and I'm working on getting a second one.
how about ghosting on it though. Honost objective opinion, do you notice the lack of CRT quality still?
Motion Blur and Ghosting are two seperate problems (I know what you just asked, please let me explain). As snipped from Anandtech and slightly edited: Streaking/ghosting refers to streaking and ghosting interference, not as a byproduct of poor response time. By definition from the VESA Flat Panel Display Manual, ghosting is actually the problem of interference over the signal, which results in an “echoed” image. However, misuse has somewhat skewed the word’s definition to also mean problems due to poor response times. To make matters more confusing, ghosting in the signal sense of the word and in the response sense are very hard to tell apart sometimes (especially if you don’t know what to look for).
Motion Blur is specifically a problem with response time and rising and falling rate. I assume that this is the actual question that you were asking about, I'm simply clearing up the symantics of it all.
I went over that slightly in my semi-large post above this one. In Doom 3 a very high contrast game that would force the pixels to have to twist and untwist constantly (which means a good tester of response time) it is difficult to see and or perceive motion blur. Even when erradically moving the mouse in order to see the desired effect (defect?) it's still pretty difficult. Games liky FarCry and HL2 where the games are much brighter in geneneral there is little if at all.
Yes this is opinion, maybe my eyes aren't as quick as yours, but I am playing on up to date hardware including a less expensive SLi setup that does allow me to get over 80 frames if I want it (naming a number over 60 here deliberately of course). And it's not just my opinion, I intentionally let friends play games on the monitor to see if they like it as well, and/or if they can notice a large issue in response time. And while yes it isn't perfect, it's damned hard to make it mess up. I only got this monitor after I tested it on my friends machine myself. This monitor as I said was finally the monitor to make me want to do the jump from CRT to LCD.
If you are a fan of Doom3/Thief, other darkish games CRTs easily outperform most LCDs with regard to black rendering (i.e., all LCDs I've seen show black as gray). I haven't seen some of the newer LCDs with the better contrast ratio but I know the 2001fp was just awful with regard to blacks (more like milky grays).
I assure you black is black on 2005fpw. I have it next to the p95+b for my current dual monitor setup, that is until I can afford a second 2005fpw.
Agreed. Black is black on my 2005fpw. On the Dell 2001 I had black was grey.
I do have a minor backlight issue on the top right of my screen where in a dark room black is dark grey. :D
The contrast ratio of the 2005fpw is 600:1. The contrast ratio of the 2001fp is 400:1. I think I read somewhere that the Hyundai L90 is 700:1 (best I've seen quoted for LCDs). The Panny plasma I'm expecting later this week has a contrast ratio of 3,000:1. CRTs are typically in the same ballpark though light reflection on the phosphors will compromise that somewhat (not an issue, of course, in a darkened room). Contrast ratio is not the be-all end-all measurement of black resolution performance. But it gives you a good ballpark indication. Bottom line is that the tech specs suggest LCDs have problems with blacks when compared to other technologies. How much of a problem it presents to you depends on how picky you are.
If you're a hardcore gamer, get a CRT. No blurring and multiple resolutions are useful if you game a lot. Also, the 2005FPW has OK blacks but not if you're playing in a dark room. It's not a bad monitor by any means and it will beat a CRT in text sharpness, geometry etc. but if you want the best gaming experience, get a good CRT.
Samsung PVA panels have had the contrast ratio of 1000:1 (and that value is underestimated as measurements have shown) for some time now. The new PVA monitor with overdrive from Samsung, can't remember it's model number, will have a contrast ratio of 1500:1. Almost as good as a CRT. Even the current 1000:1 PVA panels have visually darker blacks during the daylight. In my opinion, blacks on those panels are just not an issue at all.
the dell 2405FPW has a 1000:1 ratio, so you would say that is good? Its problably also worth mentioning the CRT (CTX VL700) im using right now is in no way new. I'v been trying to figure out its age but its got to be getting close to 6 if not more years. Its aspect ratio that i can find is 4:3. Its my understanding monitors of this age actually had worse contrast ratios then many of todays LCDs? I have no gripes with this monitor under any conditions except for the fact that it is aging and showing signs of dying soon. Also its max supported resolution is 1280x1024 @ 60Hz which wont stand for much longer for my personal needs. But because of its age im wondering if i'll notice an improvment under any circumstances with a new monitor, be it CRT/LCD.
Really, the only way to determine if an LCD has adequate blacks for your tastes is to try it out yourself on games like Doom3 and Thief. Just make sure you have a good return policy and then you can convince yourself one way or another. What anyone else says or thinks doesn't matter (especially since there is so much subjectivity involved in determining what is black). One thing I can say with certainty....there are some panels that do quite poorly with these types of games (i.e., 2001fp) as I can attest to myself, owning both a 2001fp and NEC FE2111sb CRT simultaneously.
I wouldn't read too much into contrast ratio. Firstly it's just a number, and like "averaging" or gathering other data (for instance luminocity) a lot of companies just fudge that number. I've seen LCD's (or plasma screens of course refering to something over 32" and a TV) that say they have 2000:1 contrast ratios and for some reason everything on them looks a dull grey.
I trusted my own eyes, and I saw a 2005fpw and fooled with it before I bought one. I'm just trying to pass my good experience a long. I wouldnt' say that I have a lot of experience with a lot of monitors, but I have played with a few. There is a major difference between THIS monitor and the 2001fp, I CANNOT stress that enough. That's why this monitor is getting phased in, and that one is getting phased out. With the exception of maximum resolution, this monitor is superior in every way shape and form.
However like I said earlier, the reasons to stick with a CRT or make the jump to LCD are entirely up to you. It has to do mostly with which features you want, and your price point. For $460 (because I waited for Dell cupons) I don't think you can find a better monitor than the 2005 fpw for the price point. Otherwise you could go ahead and buy a high quality 19" CRT from some other company or a medium-low quality 21".
The backlight issues alone on the 2005fpw makes me suspicious that it can produce adequate blacks. Regarding contrast ratios and numbers cited, you don't have to believe or disbelieve *one* manufacturer. But, consistently, the contrast ratios of LCDs on the whole are just low compared to other technologies. BTW, your 2000:1 figure for a plasma is typical these days. Don't confuse plasma with LCDs....they are vastly different with respect to black performance. Plasmas are approaching CRTs and LCDs are making baby steps toward improvement. It all has to do with the technology limitations....LCDs stop light from displaying to produce black and the backlighting problems it has is just one indicator why it lags the other techs.
I realize the issues with contrast ratios, but I'm making a point that it is just a number it doesn't necessarily represent accurately what the picture will look like.
However on that other issue, you're making me want to take pics and post them, but I don't have webspace. For instance this entire webpage is black, I think you'd be pretty surprised if I had half the window on the 2005fpw and the other half on the p95f+b. If this monitor was as ugly as some other ones on the market I wouldn't have bought it, and trust me when I stress that the 2005fpw is very different from the 2001fp.
If nothing else go and read anandtechs comparo between the 2005fpw and the apple 20" WS display. If you believe in Macs quality at all and you see the comparo it's apparent that the two monitors are very comparable even though they have 2 entirely seperate controllers, and backlights. The LCD panels themselves are identical (same manufacturer).
EDIT: For linkage. http://www.anandtech.com/displays/showdoc.aspx?i=2400
Contrast ratio of a good LCD 3000:1 to 3500:1
Contrast ratio of a decent crt 45000:1 to 50000:1
Enough said.
This is about best, not practical. CRT technology is infinately better than LCD for raw picture quality on PC's just as it is in home theater.
BTW have you considered the NEC/Mitsubishi 2070? It's a replacement for the 2060 which Tom's hardware said was without equal in the 22" category. Or is the dell model you mentioned the same thing? I didn't bother to look
meh........... went from a 19" crt to the dell 2oo1 fp. Lovely picture. Ive never seen a ghost, I can play any game as it was intended, I am very happy with my choice. I think its a matter of personal choice and what you like. You can quibble all you want about blacker black, blurs or ghosts, response,etc. But the quality of the picture IMO is very nice and I am very satisfied. I waffled about for months until i took the plunge and Im very glad i did. I have a 6800 ultra that runs the screen and the image is very stunning. :cool:
