LCD Monitors?
VE2007
Hi,
I am after a 26 or higher in a LCD Monitor and wondering is there any
big difference between these two Dell TM 30" 3007WFP UltraSharpTM
Widescreen Flat Panel Monitor and the Dell TM 30" 3007WFP-HC
UltraSharpTM Widescreen Flat Panel Monitor?
Any suggestions will be good, plus it will be only used for games.
The HC version is newer, has faster response time and a wider color gamut. The HP LP3065 has the same panel as the new HC Dell, have you considered that monitor?
But if it will only be used for games I would propably recommend a 37" 1080p -screen. Much easier on the video card aswell.
