LCD Monitor Problem
jaycyn94
I just picked up a BenQ 19" LCD monitor (model T903) at Office Depot and after one day it started to have a green, "flickering" fringe to images onscreen. I pullled the cable from the computer and even the "no signal" message had a green shadow. Hooking it up to a 2nd computer had the same results. I'm guessing that I got a dud for a monitor, but wanted to check to see if perhaps I was missing something in my troubleshooting.
I have posted some pictures of the problem on Flickr: Monitor pictures
I am using a VGA cable, and have ordered a DVI-D cable that hasn't arrived yet. I was hoping that it was the cable, but since I see the problem even when the cable is not atttached, I'm not sure that would be it.
Any ideas?
Slider19 said:
return it
Can't (or at least won't). It was on Clearance at Office Depot for $146 (found it on FatWallet and other sites earlier this week) as a discontinued item and they are OOS of this model. I have opened a ticket with BenQ and I am waiting on a response from them. I don't want my money back, just a working 19". From what I have seen on some threads, it isn't like this is a bad model, probably just had bad luck with mine.
killernoodle said:
Have you tried pushing the auto adjust button?
Yeah, tried that, and several adjustments via the OSD. No luck. Playing with contrast and/or brightness just moves the noise around to different highlights on the monitor. I have (very slight) hope that perhaps moving to DVI will solve the problem, but since it shows this even when unhooked from a computer I have my doubts. If I was a betting man, I would bet I have a RMA in my future.
