LCD Mod Info/Help
So here's the deal, I'm getting back from overseas soon and building a tricked-out custom top shelf AM3 gaming rig. I already have a few ideas, but am running into trouble figuring out the custom monitor I plan on building.
Some of you may or maynot have seen the LCD mod that shadowlord did Sept 07. If not check it out here-Monitor mod (lots of pics)
My plan is to do the same, but with a 4 screen set up. |2up with 2across| I've heard of setting up two side by side on one sheet of plexi to get rid of the gap caused by the casing.
Here are the _ questions I need help with.
Have I been out of the loop for that long that 15" just not that common any more? I want to use 4x15" LCDs, but can't seem to find cheep ones on newegg.
Can any one point me in the right direction for locating 4 identical 15" for cheep or recommend where to start looking?
A good guide for wire running/cable rewiring? I want to be able to use one power button for all four. I'll mount the other controls on the back of each monitor for individual tweaking.
I've got about a month before I can buy the supplies and start this thing so no in a huge rush. When I do start I'll work log it all for you enjoyment/entertainment.
