Silversierra
- Apr 20, 2005
Hello all, this is my first post here, although I've read many others' posts. First, I've never done any serious case modding, but I've done small stuff like adding filters etc. I love to modify and build all sorts of things, and I'm fairly new into computers, so I figure, hey, I love to mod stuff, I love computers, why not mod computers. It would combine my two favorite hobbies, modding and computers. I do have a cheap dremel(dremel brand, but single speed) and know how to use it(I modded my one pocket knife by cutting out the center of the blade to make it skeletonized, it was hard metal).
Ok to my idea for a mod. I have no idea if this has been done before, so bear with me. I don't know if it'll work, so ideas and advise for a first timer would be nice. My idea is to cut a window opening in my side panel of my case and install a 17" lcd flat panel monitor in the side. I think this would be awesome for lan parties, then you don't have to carry the monitor. I also am thinking of attaching two speakers below the lcd(so I'd have speakers wherever I go, without carrying them. I think it'd be like adding two 80mm fans to the side panel, just putting speakers in instead of fans. It also would then get my tower off the floor(less dust on a desk surface). I don't have the lcd yet, so I want something thin(detachable from stand too) and preferrably cheap. I think it might be a good idea to install a window between the lcd and the side panel to protect the lcd from scratches and breakage, or would it make too much glare? Any input? I'm not 100% sure I want to do this, I want to do it, but cost may be prohibitive. So will it work?
