Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Nice thanks, also im not too sure on the setup to do, I got a lcd with hdmi and vga, i wanted to test both vga and hdmi both at 720p and 1080p game mode on and off, and my mobo has 1 hdmi and 1 vga, so can i use vga for the crt monitor then hdmi for lcd to test, then vga with a splitter to test both crt and lcd? or am i confusing myself?
like hook up the crt to vga and keep it the same res with all the test, then hook up the lcd with hdmi and set res to 720p/1080p gamemode on/off then try the same with vga with a splitter?
will that pretty much show whats the best ms for my tv? so if its vga at 720p then thats what i should use on my xbox 360?
Just connect the monitors as-is with the ports you have (HD TV to HDMI and CRT to VGA) and then run the monitors in cloned mode either through Windows Display Properties or your video drivers settings and then run the timed test. Get a camera and start shooting.
ok, but i want to test my lcd's vga too, so a vga splitter will work fine? and i should always keep the crt at the same res but play around with the lcds res to see if it affects the ms? sound good?
