LCD Help!
phalnax
I was looking for LCD's with HDMI input...17" - 21" ...I need some recommendations.... :)
thanks guys...I'd also prefer them to be priced on the cheaper side...you know...$500...that's my limit....
JEEZ! SOMEONE REPLY!
I wanted to use this lcd with my xbox 360...any recommendations...20 inch... :(
Just an FYI, Xbox360 doesnt have DVI or HDMI outputs , You'd have to go with VGA or Component.
Oh. It'd be great if you could explain it a bit more. What do I want to use...component cables or av cables. What would I have to do to see the image quality i do on hdtv's? Your help would be appreciated as I'm a total noob when it comes to lcd displays.
You'll have to use component cables, thats the best of what the xbox comes with, I hear you can get a replacement cable that has HDMI though...not entirely sure.
A vga cable would be better. For me the colors are as vibrant as component. But the clearity and sharpness is on a whole other level.
