LCD good or bad for gaming ?
nicholasle
I have ordered a new system online.
The Specs are:
P4 3.6 Ghz
Abit AAX8E Fatal1ty Board
2gb DDR2 Giel Ram
MSI 6800 256mb PCI-E Video Card
My question is:
I have heard that an LCD Display wasnt good for gaming.
Is this true?
I am wanting a 19"-20" ViewSonic or Samsung
Is there something I should look for when choosing an LCD?
Or am I better to go with a CRT ?
Please Help ;)
The two games I want to play most are Half-Life 2 and DOOM 3.
Also whats the deal with ghosting ?
Is that still a problem with LCD's
CRT for gaming. /end thread.
Seriously, some people cant see the lcd blur, and others of us see it on every lcd panel out there. You might consider checking out some at stores before you decide, but yes, ghosting/blur is a significant problem on lcds. Dont believe these people who say it "isnt there", as they simply cant see it. Those of us who can see it have no reason to create a grand conspiracy designed around lying about ghosting, now do we?
Also, be aware that you're stuck at the lcd native resolution for the best picture quality, so if you get a 19 or 20 inch lcd doing 1600x1200 native res, you better have a beefy video card to muscle the game around.
If you're a pretty hardcore gamer and must have a lcd I'd check out the sony hs94p or the viewsonic 912b 19" lcds that have the greatest response times you can get right now with a 19". Also, with a good video card you'll always have great framerates at 1280x1024 in any game. I have the sony and games look and play amazing on it.
HL2 will look fine on a LCD but with all of the limitations listed by meelk.
Doom 3 will simply look bad. It is a very dark game and LCDs are famous for poor true black and variations gray (banding etc).
LCD's aren't good for anything but saving space until you get to the Apple Cinema Display's that cost upwards of $1,700. Even the kind of CRT makes a difference. There are two; aperture grille(the best) and shadow mask(the cheap). There are a couple good shadow mask's out there and even some elipse masks that try to merge the benefit of a shadow mask's sharp text with the beautiful color only an aperture grille CRT can produce. Case in point, I've had a Dell P991 for 5 years and its actually a Sony Trinitron aperture grille CRT. I bought a Samsung CRT and returned it the next day because my old Sony looks so much better. I've also seen LCD's in use and they give all kinds of crazy artifacts that just aren't factors on CRT's. Even the cheapest shadow mask CRT is going to have a better image than a $400 LCD.
I'm sorry but I dont agree with that statement. Ive had the Dell trinitron 19inch for 4 years now and thought it was great and all and was planning to get a NEC diamontron. Well this christmas i got a Vp912b and the image on this is alot more sharper and clear that my trinitron. My mom has a 1 year old Trinitron and I rather use this moniter over that anyday. Its just so much crisper and easier to read on.
Issue: Ghosting
The fact about ghosting is that it is very real and very distracting on LCD's with slow response times. Generally speaking, avoid LCD's with 25ms response times. 16ms or 12ms response times however virtually eliminate ghosting. All this means is read your specs and don't buy cheap. You should be fine with any of the newer high quality LCD displays.
Issue: Black Level
LCD displays achieve black by charging liquid crystals to provide opacity in front of constantly illuminated pixels. Black level is a little bit of a misnomer because the issue in dark games is not simply how black is black. The issue is how well does the display show the gradiants from black on up. A phenonmenon known as "false contouring", often discussed in Plasma HDTV and DVD forums describe the inability to progress from solid black through various shades of black without blockiness or synthetic looking blotchy patterns emerging. The best way to rate a monitor's ability to overcome false contouring IMO is to watch a reference quality DVD that has lots of black. Note that your DVD player/decoder has to be up to the task as well. I recommend "The Medallion" as a good DVD with lots of black/night scenes that involve a variety of textures (leather, water, neoprene, etc.) High quality LCD panels with good contrast ratios will not typically exhibit a lot of false contouring.
Issue: Interpolation
Interpolation is when an LCD panel is displaying an image in a resolution lower than it's normal native resolution. In other words, if there are 1600x1200 pixels physically present on the display, something has to be compromised to display 1280x960, 1280x1024, 1024x768, but NOT 800x600. An algorithm has to be programmed into the display to determine the best way to interpolate the lower resolution to upconvert it to the higher native resolution. In this case 800x600 does not need to interpolate since it is exactly a 2:1 ratio of 1600x1200. This is a lot like the 3:2 dropdown algorithm you hear about on DVD players that convert a film's 24fps to televisions (interlaced) 60fps. There is no science here other than the subjective. Different LCD's will handle interpolation with widely different results. Read reviews, and if possible see with your own eyes how LCD"s handle non-native resolutions.
Issue: Color Distribution
Here is one area where LCD's have a decided advantage. In a typical CRT you will often find hot and cold spots all around the screen, particularly the edges, corners, and dead smack in the middle. That is to say, the absolute brightness and color varies greatly across the surface of the screen. LCD screens tend to be much more uniform in displaying colors evenly and correctly from corner to corner.
Issue: Screen Geometry
Another win for LCD's. Whereas CRT's have images that can bend and warp, and often have very complex controls to reshape the image on the screen, LCD's by their nature have a fixed location for each pixel, and therefore tend to exhibit pretty much perfect geometry from edge to edge. To compound the CRT's problems, they often behave very differently from one refresh rate to the next, much less one resolution to the next. Therefore, unless everything you do on your CRT is at the exact same resolution and refresh rate, whenever you change either of those, you're likely not seeing very good geometry. This is my biggest complaint BY FAR about CRT displays. IMO the precision of the LCD screens makes for a much more pleasing and perfect looking image at 1600x1200, which is my preferred resolution for just about everything.
Issue: Screen Size
Lo and behold, another stunning victory for LCD's. The typical CRT screen is measured from some unknown and invisible area tucked far away underneath the plastic bezel. To compund this, most CRT's when tuned correctly can waste up to 1/2" of the visible glass surface by requiring a black border all around. The net result is that the image on a properly adjusted 21" CRT is often smaller than what you'll see on a 19" LCD. You *can* stretch the CRT to get nearly full coverage, but in most cases, you won't want to.
Issue: Refresh Rate
Most LCD displays run at lower refresh rates than their CRT counterparts. The bottom line here is that due to the widely different nature of the display mechanics, the refresh rate on an LCD is nowhere near as important as a CRT. Simply put, the CRT needs the higher refresh rate because the electron beam illimunates each phosphor only momentarily as the beam scans across each line, each pixel, one at a time. With an LCD, each pixel is constantly illuminated, and therefore doesn't need to be refreshed nearly as quickly. 60Hz on a CRT will give you unimaginable eyestrain in a few short minutes. 60Hz on an LCD can be viewed for hours on end without so much as a run to the refrigerator for more snacks.
Conclusion:
There are certainly a large number of LCD screens to be avoided for gaming. Cost isn't always the only factor either. However, the best LCD's out there IMO offer the very best display experience, bar none. I'd put either the Dell 2001FP or 2005FP (for widescreen) on my short list.
I'm going to pick up a Sony HS94P 12ms LCD, think I'll be good with that? This 19 inch CRT is killing my eyes :(
I got one for Christmas and I love the thing. The only problem with it is the 1280x1024 max/native resolution. This works well for me as it will be going on a gaming machine and I plan on running most games at this resolution. On my school/work computer however I'm going to stick with my 19" CRT so I can continue using 1600x1200 for typing/web browsing.
-zac
I just orderd a 2005FP on the 25th and I'm going to be using it for gaming. I bought this one for gaming since I wanted widescreen, I heard many positive experiences with this on this forum and Futuremark. Im also pretty sure that my system can handle all games at 1680x1050 with no AA/AF and most games with some AA/AF.
Both my HP L2335 23" Widescreen, and my Sony SDM-HX73/B plays game just great. I have no ghosting issues, plus games at 1920x1200 looks spectacular..
To each their own, but if you walk into a professional design stuido (I'm a digital graphics designer/artist), you'll usually see a bunch of Sony Trinitron CRT's and no LCD's except maybe for the Dell's at the front desk for the finance people. The professionals choice is still the CRT until you hit the IBM workstation and SGI visualization systems.
I would have to second that point. I work for fortune 500 retailer and when I visit our visual design studio they only use CRTs. The only LCDs are in the few of the manager's offices for checking email.
Why is everyone so gaga over requiring there LCD's on being 1600x1200? Im asking due to the above reply to my post saying the only thing wrong with the Sony HS94P is it being 1284x1024
Compddd said:
There aren't any 19in 1600x1200 LCD's are there though right?
I don't think there are any. 17" are better for 1024x1280 and 19" are not so good since everything is a little big.
For gaming 1600x1200 provides better IQ in many cases even without too much processing. Doom3 is a good example where 1600x1200 looks great without AA, and spectacular with 2xAA. For non gaming, you simply get a lot more desktop and application real-estate. Menus and windows borders are smaller and don't occupy such a large percentage of your available workspace. If you're used to it, it's hard to go back to lower resolutions without feeling cramped-in.
I think everyone agrees that people who have specific work requirements for CRT's will still use them. Uber-expensive CRT's can be professionally tuned to provide very accurate color representation. This is a must for designers and artists. There is also a bit of religion at play in all the artistic aspects of computer use. You'll find wanna-be marketing moguls (the corporate guys who work on low rent ad copy) who absolutely insist on a CRT even though the $500 one they use is dog-doo relative to the LCD screen up at reception. Note that a professionally tuned CRT is going to live it's life at one refresh rate and one resolution. Given that, you can afford to tune it properly. If you go to all the expense and effort to adjust a professional CRT properly and then change it's operating parameters, you've just wasted a whole lot of effort.
Equally specific, stock traders have an obvious need for LCD's due to the form factor.
How do either of those examples relate to gaming though?
rcolbert said:
Issue: Ghosting
Issue: Black Level
Issue: Screen Size
Issue: Refresh Rate
Conclusion:
Well said I use to live and die crt I would have never gone with a lcd till my old Mitsub 21 started to die out on me I then read online about the new lcd making head waves in terms of being used as a gaming monitor I did alot of reserach and found the dell 2001fp to meet my needs Im very happy with it and I wouldnt go back to a crt. Thats just me I also find the colors more rich and text to be sharp overall it looks better than my old crt did .
Well when you put it that way...
Seriously, my thought is that a group of users that picky about color and image accuracy are still exclusively using CRTs over LCDs. That said, I disagree with your point about "professionally" tuned CRT and the $500 comment.
Name a single LCD that can blow away a $500 CRT?
(straining to listening to the silence)
As for professionally tuned, hell there is number of decent shareware tuning apps that will tune any half way decent CRT to the needs of the average user.
The point here is that the difference between a good CRT and good LCD does not require benchmark application or a professional trained eye but is obviously to the average user. This is issue is no different than the visual quality differences of current televisions. The companies are marketing the hell out of various inferior technologies because of they are marketing size and style over quality. But hell if it eventually matures into something worth having then cool.
Here is my question for you, what do you do when you load up a new game and the FPS are not playable at 1600x1200? Do you lower the game quality settings? Do you just reduce the resolution and suffer the distortion?
Sincerly, I find LCD very good for gaming.
I've just bought mine today, and on HL2, HL1 and Far Cry, it's very sufficient.
But on the other hand, I find LCD not good at all on... Windows ! White color is killing my - sensitive - eyes...
It depends on the game it self other than doom3 and farcry most games can be run at 1600x1200 with any of top of the line to mid range cards out there I play doom3 1280x1024 on Med. till I find the need to upgrade my video card cod can be played fine @ 1600x1200 so can UT 2004 it all depends on the games
and your video card I find that the dell 2001fp scales well at 1280x1024 :)
I find it strange to hear people saying LCDs colors are "richer". Especially those with 18-bit panels that can only truly display 262,144 colors....whereas you can display an infinite amount of colors on a CRT, limited only by the video card. Even aside from that, the brightness of the backlight on an LCD has a tendency to wash out the colors and limit the range of colors visible on the screen at one time. The colors will not always appear to be what they are supposed to be, such as with reds, and more so if very light and very dark colors are on the screen at the same time. Colors aren't as bold, especially dark ones, because of the same problem with displaying black....the backlight washes out the colors and can't be tuned out 100%, and even if it could, leakage from surrounding areas can affect what is being displayed on a certain area. But they are still described as richer. I guess that's ok though if you are one of those people, because the hardware only has to satisfy you, and no one else. But it does remind me of the what happens when people have their HDTVs professionally calibrated for $300....While the colors are now what they are supposed to be, people are so used to watching TVs wildly off from NTSC standard that the newly calibrated TV doesn't look "right" to them, yet they are viewing what they are watching exactly as it was meant to be displayed. Interesting.
I'll take the Dell 2001FP over any $500 CRT. In fact, that's just what I did when I sold my NEC Multisync FE2111SB-BK (list $599) in favor of the 2001FP. Odd that you should choose the monitor I owned previously as your basis for comparison.
When a game won't run at 1600x1200, then, well wait a minute, Doom3, HL2, BF:V all seem to run fine at 1600x1200. Then again, the 2001FP handles interpolation very well thank you, so if I wanted to, I would TURN DOWN THE RESOLUTION (which I don't).
Do you enjoy the two horizontal lines tri-secting the screen of your NEC? They drove me farking nuts. Do you like the fact that perfect geometry at one resolution looks like a fun-house mirror in another? Do you like their calibration software that prevents your computer from suspending to RAM properly? Do you like washed out light blues (as in the sky) no matter how well calibrated the rest of the colors are? That monitor is an absolute, unmitigated POS. Too bad they didn't incorporate any Mitsubishi Diamondtron technology into it. It might have been a slightly better POS.
And speaking ot Televisions, what exactly are you saying? You're making a vague criticism of some non-specific technology and not really espousing any other, unless by default we're to assume you're also a proponent of CRT HDTV's.
I recently bought my first LCD a 19” Samsung 193P and I’m not sure I like it as far as gaming goes. The graphics in games (walls, rocks, crates, guns, floors, ect.) have a satin sheen to them. It’s as if everything was painted over with a clear satin finish, it looks unnatural to me. I guess the LCD screen causes this, but I'm not sure.
Wow, lotta ignorance floating around.
A good LCD is good for games. A bad LCD is bad for games. Its pretty much as simple as that.
I doubt that there's very much religion involved in choosing Aperture Grille CRT's over LCD's. You should look at the $9,000 IBM T221 if you want to surpass CRT genuinely. http://www.pc.ibm.com/us/intellistation/t221/index.html
There is almost nothing but religion when it comes to the artsy-fartsy crowd and their selection of technology. That wasn't the point. Comparing high-end or special use technology isn't at issue here. The issue here is very specific. CRT vs. LCD for gaming. That question implies mainstream products and prices. I have owned my share of CRT's. I have also owned my share of flat panel displays of various flavors and for various functions. At the end of the day, I prefer my 2001FP over any other display I've had, including the FE211SB..
I suppose that MaximumPC giving the nod to the 2001FP as the best LCD and noting that it handles "gaming with aplomb" simply means that the folks over there have no business running a magazine. http://www.maximumpc.com/ranking/rankings2.html
I'll be the first to admit that if you walk down the aisle at your local Best Buy and look at the LCD's on display, that 80% of them will be cheap and look pretty bad, especially for gaming.
Have you ever owned a 2001FP? If not, have you spend a considerable amount of time with one in a suitable environment? Didn't think so. I can honestly say that I have extensive experience with both the best LCD and CRT in the space we're talking about. I also dumped one for the other nearly a year ago, well before the Maximum PC reviews came out on either display. And certainly well before we started this debate. I also have a very particular eye for things, and am very satisfied with the choices I've made simply because I have afforded myself the flexibility to change my mind when I purchase something that I don't like (thank you, eBay). I didn't sell my NEC CRT a year ago to prove something to you now. I have the means to change to any reasonably priced display of my choosing, and I choose not to. I have brought my 2001FP to numerous LAN events and have had the opportunity to compare image quality in the same environment against numerous other LCD and CRT's playing the same games at the same time. Of course, all my hands on experience that I have used to form my opinions are subjective and only mean something to me. But at least I have the experience to base my opinion upon.
Or as the saying goes, "don't knock it until you try it."
I do digital content creation so I'll stick with a CRT that's never going to motion blur or have even slightly off gray tones.
P.S. Just because you do something that's artistic doesn't mean you're an "artsy fartsy" person. They piss me off in fact, but then again people who think the latest is necessarily the greatest do to. The reviews do show motion artifacting on that monitor you're talking about even though it is a good LCD.
Hey guess what, this is about a good LCD for GAMES, not "digital content creation". You wont notice any blur in-game. But then you wont notice anything, because you dont have one.
rcolbert said:
Then again, the 2001FP handles interpolation very well thank you, so if I wanted to, I would TURN DOWN THE RESOLUTION (which I don't)..
Hhhmm. Well, I guess that is where we differ. I think something that costs more should never be a compromise. Very well it is not nearly the same as equivalent.
No, I don't because I don't own that monitor. I wish I did and am considering upgrading. I am using a Viewsonic P90F which I have compared several times side by side with a Dell 2001FP that I bought for my wife and found it lacking (screen door effect, poor scaling between resolutions when compared to my CRT and poor handling of grays/blacks - the blur was noticeable but really didn't pinch my toes). Personally, I wish it did look as good as I am itching to not have a giant box my desk but I have yet to see a LCD that compares even to my lowly $300 monitor. Maybe OLED will produce better fruit.
And speaking ot Televisions, what exactly are you saying? ... we're to assume you're also a proponent of CRT HDTV's.
Yes, I am. None of the alternate technologies measure up yet. Plasma, LCD, DLP are all a sad joke for folks raised on large and larger proportions. It's like All You Can Eat sign on a restaurant that includes the word "Good" or "Fine."
P.S. By the way, feel free to use the "fuck", we are all fucking adults around here. ;) Well most of the time.
What compromise are you talking about? I would turn down the resolution if the game wouldn't run well at 1600x1200. That's a videocard side issue, not a LCD issue. By handling interpolation well I am saying that the IQ in non-native resolution on this particular screen is decidedly NOT a compromise.
Was your use-case for comparison on your wife's system gaming? What vidcard and how much tuning did you do? Sorry you didn't like it, but an opinion is just that from either of us. Of course I expect better of OLED. IMO a top of the line LCD right now is the best solution for gaming. I have yet to see an analog display that doesn't distract me in 5 different ways.
I will stand by the current generation of Plasma as the display of choice. The only drawback to Plasma is price. Longevity isn't a factor if you have the good sense to sell before the market turns cold as competing technology overtakes. HDTV CRT's have a fine picture, but their form factor and available size lessens their ability to fit into all the right places, or provide a cinematic experience versus simply watching TV. I don't miss the movie theater one bit.
When I was growing up I thought swearing was an adult thing. Now I'm quite sure it's the other way around. Come to think of it, I could make myself appear a good 10-15 years younger if I just.... FUUUUCKKKK!!!!!! (nope, didn't work, did it?)
I think it is safe to say that the CRT vs. LCD war will never die anytime soon.
There will always be a this versus that war... Piston vs. rotary, ford vs. chevy, lcd vs. crt.... the list goes on and on... I just wish the arguments could be slightly more civil... What I've learned is that Dell has a great monitor that I'm sure I can't afford. However, BenQ has a 17" monitor in the BenQ FP757 that seems to be an okay LCD, is this correct? Mind you now, I'm trying to keep my buying power below $400.00. :D
