LCD desk mount recommendation
ca_hard
Hello,
I'm looking for a simple recommendation for an LCD desk mount that does NOT require drilling.
Here's the current situation:
  • 1 x Dell 2408WFP on a typical IKEA desk.
The future situation could be something like:
  • 1 x 30" LCD landcape.
    1 x Dell 2408WFP in portrait mode off to the side.
    Same IKEA desk ;)
For now the future scenario does not exist and it'd be acceptable to have to get a new mount setup at that point.
Thanks for the help in advance!
Ergotron makes some of the best mounts around.
I've used the LX mounts for a few different monitors and have had no issues.
They also have a variety of multi monitor mounts including dual, tri, quad, ect.
www.ergotron.com
Awesome, thanks!
Looks like from the installation documentation there are a variety of mounting options, one of which looks to be independent of drilling a hole in the desk, etc. This should work perfectly.
Thanks again.
No Problem. I just use the clap method myself. No reason to drill into a perfectly good piece of furniture if you don't have to.
