LCD Desk Arms/Wall Mounts
Ataneruo
Hey all, I'm planning on buying an LCD soon and I'd like it to be easily maneuverable as well as not take up any desk space. Therefore I've been thinking about getting a desk arm for it or perhaps mounting it on the wall above my desk (VESA 100). However, these both seem to go for $100-200, which seems rather steep. Does anyone have a source for these which offers them for $50 or less?
I just got this flat/tilt wall mount. Click Here
It's awesome. Very sturdy and well built. Supports a wide rage of Vesa formats (including 100) and screen sizes from 13"-42" (incorrect on Newegg).
I imagine it will last a lifetime.
That ebay auction for the single arm says it only supports up to like 20".
I'd want to just put 1 24 on my desk, then single arm mount to position another 24 directly on top of it.
Will this arm support this?
I'm selling a $200+ wall mount for $100 if you are interested: http://www.hardforum.com/showthread.php?t=1153547
I decided not to wall mount my Westy, and consequently no longer need the wall mount I bought with it. Brand new, not used.
"Sanus VM400B Universal LCD TV Wall Mount Fits most flat panel LCDs 15" to 40", Supports up to 80 lbs, Hinged arm extends TV from 3.5" to 20" off the wall"
Model: Sanus VM400B Tilt/Swivel/Pan/Extend
Asking: $100 and I throw in the shipping.
I've found relativity inexpensive wallmounts (about $50) at Frys and Magnolia AV (aka Magnolia Hi-Fi, not sure if they have it out of state)
I've got an extra one that I'd sell you, but it only tilts up and down (no articulation) so I don't think you'd want it.
what monitor did you get this for?
i want to get it for my 37" westy. Just want to make sure it will fit before buying.
I got it for my Westy 37" wich is a 200mm Vesa. It should work just fine. I haven't recieved my screen yet, will get it tomorrow hopefully. I expect no mounting problems.
One of the things I also like about this bracket is the mounting holes are right down the middle instead of a square pattern. So it will be really easy to mount it to a stud.
