LCD Carrying Case
Snikku
Does anyone know of/suggest a carrying case or packet that I can use for lans..
The box that my NEC 1760NX came with is deteriorating away and I need a new solution..
I was talking to my friend about one who has an LCD and he told me that the carrying cases suck.. :(
But having a custom carrying case for an LCD doesn't seem like a bad idea :p
DrumBum
i would just make my own, or find a cheap plastic case that it would fit in and cut out some foam to hold the monitor
MindBuster
Just find a suitable suitcase, comes in many sizes, preferable one of those hard plastic ones for protection of the lcd.
DrumBum
the base makes what i said impossible? can't you fold up the base to make it a little smaller?
