LCD "Blip"ing
Bad_Karmal
k i just got this lcd from newegg about two months ago. its a hitachi cwx2wb i(not exact model #). after a night of it being off i will turn it on, and it will have this little like flick everyone 5 seconds or so, like the pixels become unaligned so its out of focus, just for a split second. i thought it could be the screens auto adjust features or my drivers vsync or auto fit function, but ive fooled with all the settings and no luck :eek: . it only happens for about the first five minutes being back on but its a bit annoying. also im on dvi if that helps...
check your connections.
furthermore, if you have a radeon card, enable reduce dvi frequency on high resolution displays and disable alternate dvi operational mode.
