"Lazy" hard drive
kazaakas
Hey guys,
I've got myself a new harddrive last week and so far it's been great, fast, silent, problem-free setup, but...
Sometimes when I'm listening to music (with winamp) stored on the drive, it stops for like 8 seconds and then continues, in that time, in the meantime I can hear the harddrive making some odd spinning noises.
I never had these kind of problems with winamp and my old drives before.
It almost seems that the drive went to sleep mode and that the last few mintes of a song weren't buffered and it needs to spin up again or something.
My cpu was always near idle at the time.
The drive in question is a Seagate Barracuda 2TB ST2000DM001.
Is there anything I can do to fix this problem?
Barring the normal troubleshooting techniques, my initial response is to return/exchange it, especially since you are hearing 'odd spinning noises'.
If you're wanting to be certain, run a HDD stress test in SeaTools from a bootable CD. If it goes for several hours then you can look at other things like Write Caching or Virtual Memory. As a rule of thumb, whenever I buy a new drive I burn it for 24-48 hours before loading anything onto it.
This sounds like the drive has hard to read sectors which may indicate a problem with the heads.
I recommend you install CrystalDiskInfo and see if the drive thinks it is operating abnormally.
If the drive is bad no. Its best to RMA it and use the refirbished drive Seagate will send you.
I don't think it's a bad sector, perhaps a bad motor that spins the drive platter. A bad sector would either blue-screen him or kill that music he's listening to entirely, wouldn't it?
The recovery process for a URE does not always cause a blue screen or even kill the music. Also it may be that the drive is reparing a sector that is not related to the OS or music. The firmware handles the policy of when a drive tries to recover UREs.
Can you post a SMART screenshot from CrystalDiskInfo please? That might point to start/stop failures or sector failures and give us more info to work with.
I've got to say odd spinning noises might not be the best description, what I'm hearing is a faint spin-up-ish sound and some godo old fashioned "hdd rattling sounds"
Sorry for being a noob at this, but what exactly do you guys want me to copy with CrystalDiskInfo?
I did find something that puts something on the clipboard:
Code:
CrystalDiskInfo 5.0.0 (C) 2008-2012 hiyohiyo
                                Crystal Dew World : http://crystalmark.info/
    OS : Windows 7 Ultimate Edition N SP1 [6.1 Build 7601] (x64)
  Date : 2012/06/17 16:59:11
-- Controller Map ----------------------------------------------------------
 + ATA Channel 0 (0) [ATA]
   - SAMSUNG SSD 830 Series ATA Device
 + ATA Channel 1 (1) [ATA]
   - ST2000DM001-9YN164 ATA Device
 + ATA Channel 2 (2) [ATA]
   - TSSTcorp CDDVDW SH-222BB ATA Device
 - ATA Channel 0 (0) [ATA]
 - ATA Channel 1 (1) [ATA]
 + Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller - 1E02 [ATA]
   - ATA Channel 0 (0)
   - ATA Channel 1 (1)
   - ATA Channel 2 (2)
 + Standard AHCI 1.0 Serial ATA Controller [ATA]
   - ATA Channel 0 (0)
   - ATA Channel 1 (1)
   - ATA Channel 0 (0)
   - ATA Channel 1 (1)
-- Disk List ---------------------------------------------------------------
 (1) ST2000DM001-9YN164 : 2000,3 GB [0/5/0, pd1] - st
 (2) SAMSUNG SSD 830 Series : 256,0 GB [1/4/0, pd1] - sg
 (3) SAMSUNG HM252HX : 250,0 GB [2/X/X, sa1] (V=04E8, P=1F02)
           Model : ST2000DM001-9YN164
        Firmware : CC4C
   Serial Number : W240GNNN
       Disk Size : 2000,3 GB (8,4/137,4/2000,3)
     Buffer Size : Unknown
     Queue Depth : 32
    # of Sectors : 3907029168
   Rotation Rate : 7200 RPM
       Interface : Serial ATA
   Major Version : ATA8-ACS
   Minor Version : ATA8-ACS version 4
   Transfer Mode : SATA/600
  Power On Hours : 28 hours
  Power On Count : 8 count
      Host Reads : 4104 GB
     Host Writes : 123019 GB
     Temparature : 31 C (87 F)
   Health Status : Good
        Features : S.M.A.R.T., APM, 48bit LBA, NCQ
       APM Level : 8080h [ON]
       AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 111 100 __6 00000254E5B8 Read Error Rate
03 _92 _92 __0 000000000000 Spin-Up Time
04 100 100 _20 000000000015 Start/Stop Count
05 100 100 _36 000000000000 Reallocated Sectors Count
07 100 253 _30 00000000AE4E Seek Error Rate
09 100 100 __0 00000000001C Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C 100 100 _20 000000000008 Power Cycle Count
B7 100 100 __0 000000000000 Unknown
B8 100 100 _99 000000000000 End-to-End Error
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
BC 100 100 __0 000000000000 Command Timeout
BD 100 100 __0 000000000000 High Fly Writes
BE _69 _64 _45 00001F14001F Airflow Temperature
BF 100 100 __0 000000000000 G-Sense Error Rate
C0 100 100 __0 000000000004 Power-off Retract Count
C1 100 100 __0 000000000072 Load/Unload Cycle Count
C2 _31 _40 __0 00140000001F Temperature
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
F0 100 253 __0 A15A0000000B Head Flying Hours
F1 100 253 __0 003C116918EF Total LBAs Written
F2 100 253 __0 0002011B3316 Total LBAs Read
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 0C5A 3FFF C837 0010 0000 003F 003F 0000 0000 0000  .Z?..7.......?......
010: 2020 2020 2020 2020 2020 5732 5732 3430 474E 4E4E              W240GNNN
020: 0000 0000 0004 4343 3443 2020 2020 5354 3230 3030  ......CC4C    ST2000
030: 444D 3030 312D 3959 4E31 2020 2020 2020 2020 2020  DM001-9YN164
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00                ..@./.
050: 4000 0200 0200 0007 3FFF 003F 003F FC10 00FB 0110  @.......?....?......
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000  ...........x.x.x.x..
070: 0000 0000 0000 0000 0000 850E 850E 0006 004C 0040  .................L.@
080: 01F0 0029 346B 7D09 4163 BC09 BC09 4163 207F 0076  ...)4k}.Ac4i..Ac ..v
090: 0076 8080 FFFE 0000 D000 0000 0000 0000 0000 0000  .v..................
100: 88B0 E8E0 0000 0000 0000 6003 6003 0000 5000 C500  ............`...P...
110: 49C8 83D1 0000 0000 0000 0000 0000 0000 0000 401E  I.................@.
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 88B0  @................)..
130: E8E0 88B0 E8E0 2020 0002 0100 0100 5000 3C06 3C0A  ......  ...@..P.<.<.
140: 0000 003C 0000 0008 0000 007F 007F 0280 0000 0000  ...<................
150: 0008 0000 0000 0000 0000 0000 0000 0000 5800 89E0  ................X...
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
200: 0000 0000 0000 0000 0000 3085 3085 0000 0000 4000  ............0.....@.
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000  ............... ....
220: 0000 0000 1020 0000 0000 0000 0000 0000 0000 0000  ..... ..............
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
250: 0000 0000 0000 0000 0000 62A5                      ..........b.
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 0A 00 01 0F 00 6F 64 B8 E5 54 02 00 00 00 03 03  .....od..T......
010: 00 5C 5C 00 00 00 00 00 00 00 04 32 00 64 64 15  .\\........2.dd.
020: 00 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00  .......3.dd.....
030: 00 00 07 0F 00 64 FD 4E AE 00 00 00 00 00 09 32  .....d.N.......2
040: 00 64 64 1C 00 00 00 00 00 00 0A 13 00 64 64 00  .dd..........dd.
050: 00 00 00 00 00 00 0C 32 00 64 64 08 00 00 00 00  .......2.dd.....
060: 00 00 B7 32 00 64 64 00 00 00 00 00 00 00 B8 32  ...2.dd........2
070: 00 64 64 00 00 00 00 00 00 00 BB 32 00 64 64 00  .dd........2.dd.
080: 00 00 00 00 00 00 BC 32 00 64 64 00 00 00 00 00  .......2.dd.....
090: 00 00 BD 3A 00 64 64 00 00 00 00 00 00 00 BE 22  ...:.dd........"
0A0: 00 45 40 1F 00 14 1F 00 00 00 BF 32 00 64 64 00  .E@........2.dd.
0B0: 00 00 00 00 00 00 C0 32 00 64 64 04 00 00 00 00  .......2.dd.....
0C0: 00 00 C1 32 00 64 64 72 00 00 00 00 00 00 C2 22  ...2.ddr......."
0D0: 00 1F 28 1F 00 00 00 14 00 00 C5 12 00 64 64 00  ..(..........dd.
0E0: 00 00 00 00 00 00 C6 10 00 64 64 00 00 00 00 00  .........dd.....
0F0: 00 00 C7 3E 00 C8 C8 00 00 00 00 00 00 00 F0 00  ...>............
100: 00 64 FD 0B 00 00 00 5A A1 13 F1 00 00 64 FD EF  .d.....Z.....d..
110: 18 69 11 3C 00 00 F2 00 00 64 FD 16 33 1B 01 02  .i.<.....d..3...
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
160: 00 00 00 00 00 00 00 00 00 00 00 00 50 02 00 73  ............P..s
170: 03 00 01 00 01 F6 02 00 00 00 00 00 00 00 00 00  ................
180: 00 00 00 00 00 04 00 00 05 08 08 08 08 08 08 08  ................
190: 08 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00  ................
1A0: 00 00 00 00 00 00 00 00 74 BE 15 BC 17 00 00 00  ........t.......
1B0: 00 00 00 00 01 00 00 00 EF 18 69 11 3C 00 00 00  ..........i.<...
1C0: 16 33 1B 01 02 00 00 00 00 00 00 00 00 00 00 00  .3..............
1D0: 00 00 00 00 00 00 00 00 08 06 00 00 01 00 00 00  ................
1E0: 00 00 00 00 00 10 00 00 08 00 00 00 00 00 00 01  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C  ................
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00  ................
010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00  ................
020: 00 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00  .......$........
030: 00 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00  ................
040: 00 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00  ...........a....
050: 00 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00  ................
060: 00 00 B7 00 00 00 00 00 00 00 00 00 00 00 B8 63  ...............c
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00  ................
080: 00 00 00 00 00 00 BC 00 00 00 00 00 00 00 00 00  ................
090: 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 BE 2D  ...............-
0A0: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00  ................
0B0: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00  ................
0C0: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00  ................
0D0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00  ................
0E0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00  ................
0F0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 F0 00  ................
100: 00 00 00 00 00 00 00 00 00 00 F1 00 00 00 00 00  ................
110: 00 00 00 00 00 00 F2 00 00 00 00 00 00 00 00 00  ................
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E3  ................
           Model : SAMSUNG SSD 830 Series
        Firmware : CXM03B1Q
   Serial Number : S0XZNEAC301219
       Disk Size : 256,0 GB (8,4/137,4/256,0)
     Queue Depth : 32
    # of Sectors : 500118192
   Rotation Rate : ---- (SSD)
   Major Version : ACS-2
   Minor Version : ACS-2 Revision 2
  Power On Hours : 115 hours
  Power On Count : 77 count
     Host Writes : 166 GB
Wear Level Count : 1
     Temparature : 27 C (80 F)
   Health Status : Good (100 %)
        Features : S.M.A.R.T., 48bit LBA, NCQ, TRIM
       APM Level : ----
       AAM Level : ----
05 100 100 _10 000000000000 Reallocated Sector Count
09 _99 _99 __0 000000000073 Power-on Hours
0C _99 _99 __0 00000000004D Power-on Count
B1 _99 _99 __0 000000000001 Wear Leveling Count
B3 100 100 _10 000000000000 Used Reserved Block Count (Total)
B5 100 100 _10 000000000000 Program Fail Count (Total)
B6 100 100 _10 000000000000 Erase Fail Count (Total)
B7 100 100 _10 000000000000 Runtime Bad Block (Total)
BB 100 100 __0 000000000000 Uncorrectable Error Count
BE _73 _71 __0 00000000001B Airflow Temperature
C3 200 200 __0 000000000000 ECC Error Rate
C7 253 253 __0 000000000000 CRC Error Count
EB _99 _99 __0 00000000001D POR Recovery Count
F1 _99 _99 __0 000014C3E3FE Total LBA Written
        0    1    2    3    4    5    6    7    8    9
000: 0040 3FFF C837 0010 0000 003F 003F 0000 0000 0000  .@?..7.......?......
010: 5330 585A 4E45 4143 3330 3139 3139 2020 2020 2020  S0XZNEAC301219
020: 0000 0000 0000 4358 4D30 3151 3151 5341 4D53 554E  ......CXM03B1QSAMSUN
030: 4720 5353 4420 3833 3020 7269 7269 6573 2020 2020  G SSD 830 Series
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0E00  ...........x.x.x.x..
070: 0000 0000 0000 0000 0000 050E 050E 0006 004C 0040  .................L.@
080: 03FC 0031 746B 7D01 4163 BC01 BC01 4163 207F 0003  ...1tk}.Acti..Ac ...
090: 0010 0000 FFFE 0000 0000 0000 0000 0000 0000 0000  ....................
100: 32B0 1DCF 0000 0000 0000 4000 4000 0000 5002 5380  2...........@...P.S.
110: 4358 4D30 0000 0000 0000 0000 0000 0000 0000 4018  CXM0..............@.
120: 4018 0000 0000 0000 0000 0000 0000 0000 0029 0000  @................)..
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001  ....................
200: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000  ....................
220: 0000 0000 103F 0000 0000 0000 0000 0000 0000 0000  .....?..............
250: 0000 0000 0000 0000 0000 40A5                      ..........@.
000: 01 00 05 33 00 64 64 00 00 00 00 00 00 00 09 32  ...3.dd........2
010: 00 63 63 73 00 00 00 00 00 00 0C 32 00 63 63 4D  .ccs.......2.ccM
020: 00 00 00 00 00 00 B1 13 00 63 63 01 00 00 00 00  .........cc.....
030: 00 00 B3 13 00 64 64 00 00 00 00 00 00 00 B5 32  .....dd........2
040: 00 64 64 00 00 00 00 00 00 00 B6 32 00 64 64 00  .dd........2.dd.
050: 00 00 00 00 00 00 B7 13 00 64 64 00 00 00 00 00  .........dd.....
060: 00 00 BB 32 00 64 64 00 00 00 00 00 00 00 BE 32  ...2.dd........2
070: 00 49 47 1B 00 00 00 00 00 00 C3 1A 00 C8 C8 00  .IG.............
080: 00 00 00 00 00 00 C7 3E 00 FD FD 00 00 00 00 00  .......>........
090: 00 00 EB 12 00 63 63 1D 00 00 00 00 00 00 F1 32  .....cc........2
0A0: 00 63 63 FE E3 C3 14 00 00 00 00 00 00 00 FF 00  .cc.............
0B0: 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00  ................
0C0: 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00  ................
0D0: 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 FF 00  ................
0E0: 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00  ................
0F0: 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00  ................
100: 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 FF 00  ................
110: 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00  ................
120: 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00  ................
130: 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 FF 00  ................
140: 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00  ................
150: 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00  ................
160: 00 00 FF 00 00 00 00 00 00 00 02 00 FC 03 00 5B  ...............[
170: 03 00 01 00 02 11 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90  ................
000: 01 00 05 0A 00 00 00 00 00 00 00 00 00 00 09 00  ................
010: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00  ................
020: 00 00 00 00 00 00 B1 00 00 00 00 00 00 00 00 00  ................
030: 00 00 B3 0A 00 00 00 00 00 00 00 00 00 00 B5 0A  ................
040: 00 00 00 00 00 00 00 00 00 00 B6 0A 00 00 00 00  ................
050: 00 00 00 00 00 00 B7 0A 00 00 00 00 00 00 00 00  ................
060: 00 00 BB 00 00 00 00 00 00 00 00 00 00 00 BE 00  ................
070: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00  ................
080: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00  ................
090: 00 00 EB 00 00 00 00 00 00 00 00 00 00 00 F1 00  ................
0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E  ...............N
 (3) SAMSUNG HM252HX
       Enclosure : Samsung S2 Portable USB Device (V=04E8, P=1F02, sa1)
           Model : SAMSUNG HM252HX
        Firmware : 2AC101C4
   Serial Number : C0862F121A1UCR
       Disk Size : 250,0 GB (8,4/137,4/250,0)
     Buffer Size : 8192 KB
     Queue Depth : 32
    # of Sectors : 488397168
   Rotation Rate : Unknown
       Interface : USB (Serial ATA)
   Minor Version : ATA8-ACS version 6
   Transfer Mode : SATA/300
  Power On Hours : Unknown
  Power On Count : Unknown
     Temparature : Unknown
   Health Status : Unknown
        Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
       APM Level : 0080h [OFF]
       AAM Level : FE00h [OFF]
        0    1    2    3    4    5    6    7    8    9
010: 4330 3836 3246 3132 3141 4352 4352 2020 2020 2020  C0862F121A1UCR
020: 0000 4000 0004 3241 4331 4334 4334 5341 4D53 554E  ..@...2AC101C4SAMSUN
030: 4720 484D 3235 3248 5820 2020 2020 2020 2020 2020  G HM252HX
050: 4000 0200 0200 0007 3FFF 003F 003F FC10 00FB 0000  @.......?....?......
070: 0000 0000 0000 0000 0000 1F06 1F06 0000 004C 0040  .................L.@
080: 01FF 0028 746B 7F69 6123 BC41 BC41 6123 407F 0020  ...(tk.ia#ti.Aa#@..
090: 0020 0080 FFFE 0000 FE00 0000 0000 0000 0000 0000  . ..................
100: 5970 1D1C 0000 0000 0000 4000 4000 0000 5000 0F00  Yp..........@...P...
110: 1AFB C010 0000 0000 0000 0000 0000 0000 0000 401C  ..................@.
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 0000  @................!..
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000  ....................
200: 0000 0000 0000 0000 0000 003F 003F 0000 0000 0000  .............?......
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
220: 0000 0000 101F 0000 0000 0000 0000 0000 0000 0000  ....................
230: 0000 0000 0000 0000 0001 0000 0000 0000 0000 0000  ....................
250: 0000 0000 0000 0000 0000 93A5                      ............
000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
If it's only a week old and behaving strangely, return it. Immediately. It can only get worse going forward.
This might be exactly the problem though. I've the same thing happening to me when playing music from a non-OS drive that has sleep-mode activated. How about simply disabling sleep mode for that drive and see if it still happens?
Agreed. Originally I was thinking about that however I was not sure by the way the OP described the situation. Now when I have looked at the SMART (not showing anything abnormal) I believe it is the windows default 20 minute power down is causing this..
Yep, so stupid of me not to check the power management settings, and indeed it was at 20 minutes */facepalm*
Just disabled it, I'll see if the problem persists.
Honestly I believe there's nothing wrong with the drive. I have strong faith now in the fact that the root of the problem was that all my small apps and my OS are on the SSD. So the HDD has long periods of non-usage which triggers the sleep mode, which requires time to spin up again, explaining the spinning noises during the winamp breaks.
In all honesty the drive shouldn't sleep if it's being read from, but hopefully that will fix it.
I know, but I don't know how winamp caches its audio files into the memory, so can't say for sure.
Anyway, the problem hasn't shown itsself again since changing the option, so I'm hopeful.
