Lazer TV ?
Essentially this is a DLP tv using laser light source. Getting the lasers price reduced is the challenge of the moment. Apparently the power supplies for the lasers are still large, hot and expensive.
You can get essentially the same result today using LED based DLP. It does pretty much the same thing. Removed the color wheel and projector bulb, increases the color range. But Laser sounds so much cooler. But this is still a projection technology and will look much like other rear projectors. Unless I was going really larger, I would prefer Plasma/LCD.
