I'm in the process of trying to move our companies network over from a public address range (199.0.9.x/24) which we dont own to a private range (192.168.200.x/24). I have a catalyst 3550 that I want to do the routing with. I have two vlans set up, one for the old subnet and one for the new subnet. Both vlans have a virtual interface. I have two machines in each vlan that can ping their respective virtual interface. I can ping each interface from the switch. Both vlans show up in the routing table but they will not route between one another. Heres some relevant info from the switch. Need some help. Thanks
and some show commands
Code:
catalyst3550#sh run
Building configuration...
Current configuration : 5455 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname catalyst3550
enable secret 5 *******************************************
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode mst
spanning-tree extend system-id
vlan internal allocation policy ascending
interface Port-channel1
switchport mode access
shutdown
interface Port-channel2
shutdown
interface Port-channel3
switchport mode dynamic desirable
shutdown
interface Port-channel4
shutdown
interface FastEthernet0/1
switchport access vlan 2
interface FastEthernet0/2
... removed ...
interface Vlan1
ip address 192.168.200.1 255.255.255.0
interface Vlan2
ip address 199.0.9.2 255.255.255.0
... removed ..
Code:
catalyst3550#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 199.0.9.0/24 is directly connected, Vlan2
C 192.168.200.0/24 is directly connected, Vlan1
catalyst3550#show int vlan1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 0017.956f.de00 (bia 0017.956f.de00)
Internet address is 192.168.200.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:01:30, output 00:01:58, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/57/0 (size/max/drops/flushes); Total output drops: 5
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
5753560 packets input, 718270615 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
23726 packets output, 3097765 bytes, 0 underruns
0 output errors, 0 interface resets
0 output buffer failures, 0 output buffers swapped out
catalyst3550#show int vlan2
Vlan2 is up, line protocol is up
Internet address is 199.0.9.2/24
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7
5 minute input rate 3000 bits/sec, 2 packets/sec
5 minute output rate 2000 bits/sec, 2 packets/sec
10554515 packets input, 1284335830 bytes, 0 no buffer
Received 0 broadcasts (24631 IP multicast)
19839 packets output, 1439295 bytes, 0 underruns
