Last min advice..
TheToE!
[H] Brewmaster
Im about to pull the trigger on a fortron blue storm, ive got around a $100 budgeted for a psu thats going to power the following rig :
3200 Venice
DFI - Ultra-d
2 SATA's in Raid -0
+ the usual (x800 , ect.)
I plan to oc.
For $100 can you think of a better psu?
Thanks in advance!
TheToE! said:
What you guys think about the Forton?
It is good for basic spec compliance but with your budget there may be better alternatives in the ones I suggested you at least look at.
Thanks for the advice bro! Would you say that those 3 are better than the Fortron?
Yes but for different reasons on each. The seasonic is quieter, and more efficent. The Antec has 3% load regulation. And the Enermax has the max spec of 18amps per 12v.
For the particular rig im going for , which would you suggest?
Any will work. I would personally prefer the Antec since it is a killer deal or the Seasonic because it is quiet. I like quiet systems.
