Monkeypillow
- Aug 30, 2006
I've remounted my water block a few times now, but I'm still seeing one core reach about 10C higher than the others. What gives?
For TJ-Max values, click the settings button at the bottom.
As for the odd ball cores, you are getting uneven mounting pressure. Is the back mounting plate flat, or, is it bumped up on any resistors? Also, try multiple mounts changing orientation. I've seen people go through several remounts until the cores were within 2c of each other. I think the GTZ has a slight bow to it, so mounting orientation is critical.
I mounted the GTZ as shown in the manual, so there shouldn't be a problem. Some of the mounting thumbscrews are easier to turn than others, while some give me a bit of trouble.
