Large drive, dismal failure rates?
vr.
I'm looking at going from a 6 x 500GB in RAID 6 array on an Areca card to... bigger... but the reviews out there of DOA and early failures is depressing.
What 2 TB+ drives are you guys buying that arrive alive and is any one vendor proving better than another?
At work where I have 100+ drives in raid6 My 2TB 7K2000 or 7k3000 hitachis are running fine in raid6. So are my 1TB WDC black drives. I have only RMAd a few of these. I am not using HW raid however. I use linux software raid. I have had serious high failure rates with Seagate 7200.10s, 7200.11s or 7200.12. I have had to RMA 7 of these this year to go along with the 10+ last year and 10+ the year before that. This is out of about 75 of these seagate models which I consider rediculous And no it is not the firmware bug.
Edit: With HW raid you are going to want to go hitachi anyways because of not being able to set TLER on all other manufacturers drives.
Can you set TLER on hitachi-drives? I know they are a lot better behaving with raid-cards, but is there a way to manually set TLER?
+1 on the 5k and 7k 2000 & 3000 Hitachi drives. I have them in arrays at work and home, and have not had a single problem with them. I am now just left with 1 Seagate array and have decommissioned all the others because of issues. I won't even deal with the RE WD's anymore because of previous problems. As long as the Hitachi drives stay rock solid I will stay with and recommend them!
What kinda problems did you have with RE drives? I've had pretty good luck with them, Constellation ES2 and Hitachi drives.
+1 Hitachi. Generally inexpensive, before the flood at least, and apparently built to withstand the abuse of petty mortals.
Love my WD's too, but I only buy their single platter drives.
I just picked up 8x2TB Hitachi 5k3000's for an array at home. Will be using ZFS and doing a 6 drive RAIDZ2 (~similar to RAID6) with 1 hotspare, and then an idle spare for if I need a replacement.
Is it highly unlikely to buy a cool-spin Hitachi disk today and in 2 years when it dies, receive a WD Green as a "comparable replacement" due to the acquisition?
