Laptop with IPS and discrete GPU
Time Mage
Hi, I was originally going to get the UX32VD because of the IPS display and graphics but it is out of stock everywhere. Does anyone have any suggestions for a laptop with 1600x900+ resolution, IPS display, and 13-15 inches? I might just wait for it to go back in stock but I figure it can't hurt to look around. Thanks.
I think if you go with the workstation models by Dell (Precision), Lenovo (W series) or HP (Elitebook) they will fit your needs.
Gigabyte has a 14inch 1600x900 Ultrabook with a GT640 but I don't think its a IPS screen shipping soon.
Ended up getting a laptop from Sony Outlet. Doesn't have IPS but good specs otherwise.
Processor: 3rd gen Intel® Core™ i5-3210M processor (2.50GHz / 3.10GHz with Turbo Boost)
Chipset: Intel HM77 (SPEC03000001549)
Color: Black
Display: 13.3" LED backlit display (1600 x 900)
Finger Print Sensor: Biometric Fingerprint Sensor
Operating System: Windows® 7 Home Premium 64-bit
Optical Drive: Blu-ray Disc™ player
Wireless Display: Intel® Wireless Display technology
Season: 12/Summer
Memory: 8GB (4GB fixed onboard + 4GB removable) DDR3-1333MHz
Microphone: External Microphone
LAN: 1000BASE-T
USB: USB2.0BC x1 + USB3.0 x2
Build: 2012/2Q BOM
Hard Drive (Storage): 640GB (7200rpm) hard drive
Graphics (Video Card): NVIDIA® GeForce® GT 640M LE (1GB) hybrid graphics with Intel® Wireless Display technology
Battery: Internal lithium polymer battery (4400mAh)
Memory Card slot: (Memory Stick Duo slot/PRO-HG/MagicGate/-/-/-)x1+(SD Memory Card slot/SDXC/CPRM/
Per Unit Price: $965.99
Description: CLEARANCE - Customized SVS13A190X Series Laptop
How much did that run you if you don't mind?
$1,027.33 after tax and free shipping. I was pretty happy with it considering the Vaio 13Ps start at $1129. Also I'm pretty sure it qualifies for the rebate on their page so I should get a $100 prepaid visa.
